Author Topic: Visby Corvette 1/72 build  (Read 10210 times)
T888
« on: April 19, 2025, 09:01:25 am »
As I’ve parked my Type 26 build, I’ve always wanted to building the Visby corvette. After digging out the plans I had in store I found a pair of Graupner small jet drivers.
So last week I ordered some sheets of plastic card which I got Thursday. I’ve already cut out the bulk head patterns and started to transfer them to the card.
Regards David
philk
Re: Visby Corvette 1/72 build
« Reply #1 on: April 19, 2025, 10:25:56 am »
Love this boat mNy years ago a former treasurer of the cygnets club built one looked great on the water
« Reply #2 on: April 19, 2025, 03:33:11 pm »
        :-))   O0
T888
« Reply #3 on: April 22, 2025, 09:48:56 am »
Over the week end I’ve cut out the bulk heads and started the hull construction.
I installed the jet drives and have found I need the modify the reversing buckets as they clashed.
Regards David
« Reply #4 on: April 22, 2025, 04:41:24 pm »
are they handed ?, and if so, what would be the consequence of reversing the handing as it looks like the buckets are not symetrical, assuming the sorter side is not outside i.e. pic 951 is the port side
T888
« Reply #5 on: April 22, 2025, 06:21:32 pm »
Hi warspite,
The buckets are handed, but the props are not. The modified sides face inwards to the centre line, so the wash will I hope run under the hull and give reverse flow.
From what I’ve found on previous jet drive projects is the buckets are only used at slow speeds (can steer in rever using the buckets) or emergency stop.
Regards David
« Reply #6 on: April 22, 2025, 10:55:27 pm »
I see now pic 951 is the bucket modified by cutting it.  :-))
T888
« Reply #7 on: April 24, 2025, 04:02:42 pm »
Hull nearly completed, just need to fill and sand ready for priming also need to add spray rails.
Once I’m happy with the finish I’ll add the hull openings and the main intake vents. The opening as there flush on the actual ship I’ll do by using solar film. This is very very thin and once topcoat is applied they will just be visible.
Regards David
frogman3
« Reply #8 on: April 24, 2025, 06:08:04 pm »
HI Dave what happened to the belfast you was building ?
chrisb :-))
T888
« Reply #9 on: April 24, 2025, 07:44:50 pm »
Hi Chris,
I’ve put it on hold as I was finding the base draw info I was using was way off and after seeing actual photos of the T26 I was having to do to many major mods
Regards David
frogman3
« Reply #10 on: April 25, 2025, 09:00:51 am »
HI Dave yes i see your point no good buildin the part if on the real ship they go an alter it is it  so makes a lot of work for nothing but i'll be followin  as im goin for a sail sunday up at norwich pond with my norfolk first time this yr just got to hope she still works  okas she hasnt been powered up for a yr or so just hope for nice wheather
ATB SIR
chrisb
T888
« Reply #11 on: April 30, 2025, 08:44:15 am »
Hi All,
Progress to date
Regards David
« Reply #12 on: April 30, 2025, 08:56:57 am »
Getting on well with her Dave.
T888
« Reply #13 on: April 30, 2025, 10:51:17 am »
Thanks Bob,
I’ve just dug out a 1/72 NH 90 helicopter kit which will go no the flight deck.
How’s life in Scotland ?
Regards David
littoralcombat
« Reply #14 on: May 01, 2025, 02:29:35 am »
Great progress, very nice work Sir!
By coincidence, the Company I've worked at for over 20yrs designed, built and still maintains some equipment on these that is associated with the Waterjets/Ride-Control System. Namely, the Interceptor Plates on the Transom.
Our Engineers were always impressed by them during Service Work.
Nige
T888
« Reply #15 on: May 01, 2025, 08:14:18 pm »
Thanks Nige,
Photo of the actual stern
Regards David
littoralcombat
« Reply #16 on: May 02, 2025, 02:26:03 am »
Good picture Dave.
The four Hydraulic Cylinders that raise and lower the two Interceptor Plates are clearly visible, not to be confused with Trim Tabs (which is often the case), that these Ships do not have.
Nige
T888
« Reply #17 on: May 05, 2025, 01:23:26 pm »
Update,
I took the model to the pond yesterday to test for leaks and ballast trim. Two things came to light was a small leak around the jet drives and needed a bit of ballast to be added.
Next is to things to do is seal the leaks and fix the ballast in place and start to top coat the model.
I’m also a bit concerned about the motors (555) not having the power to push it along at a good rate, may need to upgrade (speed600) them, but I don’t really wish to go down brushless route. {:-{
I’ll post some pic once I’ve completed the top coat.
Regards David
T888
« Reply #18 on: May 05, 2025, 10:59:26 pm »
Pic of the mode so far, still need to make the main gun plus a few other bits.
Regards David
Chris67
    • La mini-flotte de Lamiral67
« Reply #19 on: May 06, 2025, 02:16:54 pm »
Hello !
Nice work !  :-))
It’s in one of my projects.
T888
« Reply #20 on: May 06, 2025, 03:49:19 pm »
Thanks Chris67,
I’ve done a second test today and the motors I’ve installed are just not powerful enough, so I’ll be changing them.
Regards David
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
« Reply #21 on: May 06, 2025, 05:41:45 pm »
Thanks Chris67,
You'll eke out more rpm by removing the 555 torque rings. You'll double the power with 30% higher voltage.
T888
« Reply #22 on: May 06, 2025, 08:36:33 pm »
Thanks,
I’ll try removing the rings, I’m running 11.1 Lipo’s.
I did look up the Gruapner data on the mini jet drive, they recommend speed 600 rpm 18200 @ 8.4v
Regards David
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
« Reply #23 on: May 06, 2025, 09:27:23 pm »
The 555 no-load rpm will still be too low for a jet drive at 3s. And I think those who suggested 555 motors missed that detail and were thinking 1/72 multi blade props.
555s would have been a good match to the first batch of props of Chris's Tiger at 4s, perhaps 18v Pb.
Chris67
Page created in 0.03 seconds with 21 queries.
