Author Topic: Battery/ motor/ ESC  (Read 7241 times)
howie55
Battery/ motor/ ESC
« on: April 30, 2025, 10:31:33 pm »
Hi  everyone I have a Mtronics motor M500 , and a 7.4v1500 mAh battery, if these are compatible, I would also need to know what kind of speed controller I will need to give me a get me out of trouble for reverse and forward control on the motor, l have a 58 “ long by 15” beam yacht based on a VO 60 ocean racer, I have a 35mm prop in situ
Any help would be great
Geoff ( Howie 55
Re: Battery/ motor/ ESC
« Reply #1 on: May 01, 2025, 07:58:17 am »
Mtroniks M500 Technical Specification:
Motor Type                Brushed
Motor size                 500
RPM@12.0V             9250
Stall current @12V    8.45A
Shaft diameter          3.17mm
Length                     56.0mm
Diameter                  35.8mm
Weight                     167.0g
https://www.mtroniks.net/prod/Motors-For-RC-Boats/M500.htm#description
So anything 10AMps and above should do it:
https://www.mtroniks.net/cat/Boat-Speed-Controls
Akira
« Reply #2 on: May 02, 2025, 12:58:51 pm »
As martin's spec sheet indicates, you have a bit of a mismatch between your motor and your battery. First is the voltage. Your pack will not allow that motor to turn up and give you the speed you want. second is the battery capacity. While the stall current is 8.5 amps, I would expect t that the running amps to be around 2. With a 1500mah (1.5 amp) battery that does not give you much in the way of capacity, ie, very short run times. Given the size of your boat, you could easily increase your battery pack size. :-)
howie55
« Reply #3 on: May 05, 2025, 11:01:03 am »
Hi Akita
Thank you for your reply, the yacht has been fitted with the M500 motor, I chose it for its slow speed, I was given the battery but did not take into account the running time, do you have any suggestions for a new battery
Regards Geoff
Abandon Ship
« Reply #4 on: May 05, 2025, 01:56:00 pm »
Hi Howie, If Akira's estimate of 2A while running is correct you should get about 45 mins of run time from a good 1500mah battery. If it's had some use before you got it, it may have lost some capacity so say about half an hour. How much 'trouble' do you expect to get in for a single sailing session?
I would suggest using what you have and try it out before you get into trouble so you know what run time you get.
howie55
« Reply #5 on: May 13, 2025, 07:01:00 pm »
Thanks for replying Dave, I will fit the wiring system in, and then fill the bath and try it out with a fully charged battery and let it run, will let you know the result, it will also be the first time it’s been in the water so will check for leaks and prop shaft seal, rudder seal
Regards Geoff
Page created in 0.888 seconds with 21 queries.
