Author Topic: Paddles  (Read 5874 times)
LightermanII
  • Model maker without a clue
  • If the phone doesn't ring..... It's ME!
Paddles
« on: June 14, 2025, 09:48:16 pm »
Hello all!
It's been a while.
I have come back to my boat and ship modeling after a break.
[size=0.9375rem]
Euston.... We have a problem!
I floated my model paddle tug for the first time.
Apart from a couple of small leaks, She is not buoyant enough! The paddle boxes and sponsons are far too close to the water.
I might have to look at removing a lot of weight  from the hull and the superstructure, The paddle boxes are wood clad brass and aluminium.
The casing and flue are made from thin gauge nickel-silver.
I need to put a smaller battery/s in but I want to avoid that.
I thought I would have had buoyancy to spare but any help / ideas offered to get her to float higher.[/size]
[/size][size=inherit][/size]
[size=inherit][/size][size=1.25rem]No comments yet[/size][/size]
[size=inherit][size=inherit]
[/size]
[size=inherit][/size][size=1.0625rem]Be the first to comment.[/size][/size]
[size=inherit][size=0.9375rem]Facebook[/size][size=inherit]
[/size][size=0.9375rem]Facebook[/size][size=inherit]
[/size]
I should not have done it like that.
JimG
Re: Paddles
« Reply #1 on: June 15, 2025, 01:15:07 pm »
Are there photos missing here?If removing weight doesn't help then the only option is modifying the hull by adding some extra depth.  While not for the same reason I did this with the old PBM paddle steamer, adding a 1/2 inch balsa block to the base of the hull. This was to allow for the fitting of a lead strip outside the hull to improve it's stability as it tended to lean over to one side under way.Jim
Dundee Model Boat club
LightermanII
Re: Paddles
« Reply #2 on: June 15, 2025, 08:22:15 pm »
Hello Jim.
Yes there were some pictures of shame!
I had the self same thought as you save that I would make one in the expanded polystyrene with a GRP shell on it. it will bolt on the bottom as I made some bushes with tapped holes I did this with a view to not only for display but to add an acrylic keel as you say paddle boats are a bit of drunken old ladies and do roll!
Re: Paddles
« Reply #3 on: June 15, 2025, 08:54:23 pm »
Really  want to look but sadly cannot open the pictures  :((
JimG
Re: Paddles
« Reply #4 on: June 16, 2025, 01:00:34 pm »
Hello Jim.
I found the extra depth and the external weighted keel did help but the final fix was to open up the slots in the paddle boxes, they would fill with water on one side and tilt it over. Non feahering paddles didn't help this.
Jim
dodes
Re: Paddles
« Reply #5 on: July 09, 2025, 07:10:16 pm »
I have had similar problems with my Glasgow, a lot to do with water trapped in the paddle box's. Though I did wonder if the paddles were turning too fast, or paddle box's too small. Never mind it is a change from a screw boat.
Page created in 0.012 seconds with 15 queries.
