Author Topic: cheddar models boiler  (Read 1759 times)
pipercub1772
« on: July 25, 2025, 06:04:33 pm »
HI I have a what i think is a cheddar mark 1 boiler ,the one that has the poker burner , couple of things dose anyone have the boiler diagram i have 1 for the later version, also it dose not have a water gauge fitted and would like to fit one i would assume the bush at the side of the fire hole and the one on top of the boiler slightly offset from the centre are the connections i could use, also would the brass extension tubes be available or would i have to make them myself i would get the actual water gauge from Gerry at  Clevedon steam ,also is there a ceramic burner that would fit instead of the Sievert type burner ,sorry its a bit long ,regards Allan,
Re: cheddar models boiler
« Reply #1 on: July 25, 2025, 07:35:22 pm »
Many here could help, could you please post a few pictures  :-))  and we will have a better idea
pipercub1772
« Reply #2 on: July 25, 2025, 07:55:26 pm »
Thanks will try ,
KBIO
« Reply #3 on: July 26, 2025, 07:45:31 am »
Hello Pipercub !
Phil is right , there is so many types of Cheddar boilers. Some are even stamped Stuart ! They are very efficients boilers.
The Mark one is a (if not wrong) small vertical boiler .
Gerry is the one to talk too and he will most probably recommend a (kind of) ceramic burner.
[size=78%]https://www.clevedonsteam.co.uk/product/large-firetube-burner-for-model-steam-boilers/[/size]
I would NOT use a Sievert (good for torch and eventually large horizontal boilers ) for your boiler as you don't know what size jet is in it .
Have a look at this post , if it can help :
[size=78%]https://www.modelboatmayhem.co.uk/forum/index.php?topic=69099.0[/size]
Let us know ... !
pipercub1772
« Reply #4 on: July 26, 2025, 12:26:46 pm »
Thanks so far I've sent martin some pictures by email asking if he can upload them for me ,regards Allan
