Pages: 1 [2] 3   Go Down
Author Topic: 1/96 HMS Alacrity Type 21  (Read 5302 times)
KitS
Re: 1/96 HMS Alacrity Type 21
« Reply #25 on: September 22, 2025, 08:35:23 am »
Also I’ve corrected plans where the shafts aft bearings changed from “A” to “P” as per KITS info.
No, it wasn't me, it was Nige (littoralcombat) who pointed that out.
Kit
T888
« Reply #26 on: September 22, 2025, 10:21:22 am »
Opps
Thanks goes to litteralcombat
Regards David
T888
« Reply #27 on: September 22, 2025, 11:41:14 am »
So I only have to take off the superstructure when I need access for maintenance and battery change. I’ve put the main power and aux power switches at the stern which access is via a removal section of the flight deck.
Regards David
littoralcombat
« Reply #28 on: September 23, 2025, 02:22:21 am »
Opps
No Worries David, I knew what you meant  :-)) .
T888
« Reply #29 on: September 23, 2025, 05:04:28 am »
Electronic being installed.
Plan is to have install LEDs lights in these areas as I build them,  hanger, flight deck, nav, bridge main mast.
Regards David
T888
« Reply #30 on: September 26, 2025, 11:49:22 am »
Water tight doors First of a few mould I’ll need to make.
Regards David
« Reply #31 on: September 26, 2025, 10:19:11 pm »
Dave, the Glasgow Richmond Model Boat Club used to power their Type 21's with Deccaperm Motors. The racket from the gearboxes used to sound like Gas Turbines.
Detomo
« Reply #32 on: September 27, 2025, 02:17:22 pm »
Hi , as you know i,am interested in this build. Putting lights in your build but you do not list the parts used or components , if you could please.
T888
« Reply #33 on: September 27, 2025, 03:09:11 pm »
Detomo,
My setup uses the following Scalewarships components
12 v distribution board for power distribution, this unit I plug in a 11.1 3c lipo battery.
The board has a 5v 3A UBEC (Universal Battery Eliminator Circuit) I use this for powering the 8 ways switch
8 way switching unit
This unit I use to switch no / off , radar,  LEDs  in different areas ie hanger, nav, bridge etc.
LED Bus bars are used to power up multi LEDs for the flight deck. These bus bars are Switched using the 8way unit.
I’ve built a control box which houses a 10 channel receiver two 30amp mtronic ESC and a cooling fan. This control box can be unplugged and transferred to multi of other of my models.
The LEDs are 12v pre wired 0.5 mm purchased from Amazon
Regards David
T888
« Reply #34 on: October 02, 2025, 11:03:37 am »
Hi Gents bit of an update,
First pic is really for Paul (KingP) and is how I’ve build the first part of the super structure. I know some you may think this is to fragile but as I need to keep the top weight a light as possible, then this what I’ve done. It’s also worth noting I only require to remove the superstructure to change the battery and maintenance. Switch on/ off is done by the flight deck access.
The second pic is the hull ready for black boot line and hull grey, next is to finish off the deck edging and mark fitting locations.
Regards David
King P
« Reply #35 on: October 02, 2025, 01:44:35 pm »
Thanks T888
littoralcombat
« Reply #36 on: October 02, 2025, 08:24:02 pm »
Great progress David, she's displaying those classic Type 21 lines that never seem to get old in my book.
I'm thoroughly enjoying your build log.
Nige
KitS
« Reply #37 on: October 02, 2025, 08:27:53 pm »
She looks as if she's doing 25 kts just sitting there!  :-))
Kit
T888
« Reply #38 on: October 02, 2025, 09:17:45 pm »
Thanks Gents for your lovely comments.
Yesterday and to day I’ve been doing some filler primming and making fittings.
When I was going to college for my marine apprenticeship, I used the fairy that pass Vospers where some of the type 21 were fitting out.
Always loved them and wished to make one, 50 years on I am {-)
Regards David
T888
« Reply #39 on: October 25, 2025, 09:52:26 am »
Just returned from hols, suffering some jet lag so spent this morning filler priming and tell painting on a couple of parts I made before my hols.
Photos of the funnel part of the superstructure.
Regards David
T888
« Reply #40 on: October 26, 2025, 10:38:33 am »
Little more work done on the funnel
Regards David
Akira
« Reply #41 on: October 26, 2025, 09:34:41 pm »
SWEET :}
frogman3
« Reply #42 on: October 26, 2025, 09:47:15 pm »
HI Dave long time no talk as ive been offline but back on now on windows 11 laptop an what a lot of hassle its been to get this laptop goin an your 21 is lookin good hope you are well an andrea
ATB
chrisb an jen :-))
T888
« Reply #43 on: October 27, 2025, 03:47:40 am »
Hi Chris,
Pleased your back, we are both all good, just got back from hols.
Will be focusing on this project for now.
Regards David
frogman3
« Reply #44 on: October 27, 2025, 08:30:58 am »
great stuff Dave will be lookin forward to this type 21 as i built a type 21 in 1/64 scale hull that the MOD use to  test hull for the real ships an by gum it was a job to get it to sail without turning turtule
had to fix a large lump of lead on her keel then she sailed ok it was FI69 HMS AMAZON  :-))
CHRISB :-))
T888
« Reply #45 on: October 27, 2025, 12:28:41 pm »
Hi Chris,
Funny you say about the hull you had, when I gave up model aircraft in the 70s and move to boats a member in the club I jointed had a hull from the MOD testing facilities. His model inspired me to build the best model I could(still trying). His model was of HMS Antelope, from what I remember the few times he put it on the water, it sailed well, I think he had a external lead kell.
Regards David
frogman3
« Reply #46 on: October 27, 2025, 10:36:36 pm »
Hi Chris,
WELL DAVE without a lead keel wheighin in at 8  pounds  it sailed like a drunk pig an i nearly lost her on one occation an my freind has the same hull in 1/64 scale again ex MOD hull an his sailed the same so he still has his 21 an the big hunk of lead on the keel  an his ship is HMS AVENGER cant remeber penant no.
chrisb
T888
« Reply #47 on: November 01, 2025, 04:32:59 pm »
Progress so far. Plan is to start on the bridge section, it’s too damp to paint the hull grey. I need to get some diesel for my heater so I can get my workshop warm to spray the hull.
Regards David
T888
« Reply #48 on: November 04, 2025, 03:18:33 pm »
Very frustrating day to day, started building the bridge section only to find errors in the drawing which resulted in me having to spend hours measuring checking both sheet of the drawing. I’ve now marked up the drawings and corrected areas where the drawing seems to have stretched and distorted. I can only assume that when the drawing was reproduced by the printers for sale they have distorted.
Bridge section rev 3 after corrections
Regards David
« Reply #49 on: November 04, 2025, 10:56:33 pm »
Hi David, well at least you're seeing these anomalies at a reasonably early stage in the build - this whole hobby of ours is one long, continuous challenge aint it !! O0
Cheers,
Pages: 1 [2] 3   Go Up
