Author Topic: Rubber Bow Fenders for Tugs  (Read 7959 times)
bosun
    • bosunsmodelboats.com
« on: November 15, 2007, 09:43:36 am »
Hy Guys
What are you using for the  fixed rubber bow fenders on your tugs. I have tried PC mouse mat but it does,nt look right, is there something avalliable comercially I could use.
Many Thanks
Bosun
cos918
Re: Rubber Bow Fenders for Tugs
« Reply #1 on: November 15, 2007, 04:16:41 pm »
hi there if its the bow or stern fender you could use a car fan belt or car cam shaft belt as the both have teeth in them. So cut it to lengt and glue to the boat teeth side out. O0 john
Umi_Ryuzuki
« Reply #2 on: November 15, 2007, 04:53:27 pm »
What style are you looking for?
I have one that replaces the bow fender for the Tito Neri.  :)
And am working on a slightyly larger piece that tapers from 63.5mm(2.5") down to 19mm(3/4")
http://mysite.verizon.net/res1tf1s/id12.html
tubby tomo
« Reply #3 on: November 15, 2007, 06:33:13 pm »
hi depending on scale i use the tyres from rc monster trucks i cut them to size then put a stripe of lead in the cut peace of tyre to keep the shape of the bow
bosun
« Reply #4 on: November 15, 2007, 11:01:46 pm »
Hy Fellas, and of course you Umi,
Thanks for the input, I think I will be looking at the cam belt option, its the bow fender for the Nangee that I want to finish, so I need that square block type look. My other tugs have either rope or tyre fenders doing the job, the Nangee is a bit different as it is a newer build.
Umi I have always liked the work that you do with your models, and its nice to see you having an input on the Mayhem site.
Once again
Many thanks
Bosun
portside II
  • tugs at rest
« Reply #5 on: November 16, 2007, 01:24:27 am »
Bosum
i use foam rubber that i picked up at a model aircraft rally ,comes in different densitys and colours
also a rubber protective mat that they use on the docks ,acts as a none slip matting for the trailers and loads /pallets.
If you want some of the latter let me know  10 x 5 inch sheets half inch thick grainy but dense.
daz
bosun
« Reply #6 on: November 16, 2007, 04:12:53 pm »
Hy Daz,
Thanks for the offer of the rubber mat, thats very kind of you. I will have a look around the docks at Newport, see what I can find, I think I know the stuff you mean, but cant remember where I saw it. If I cant get any I will get back to you if thats ok.
Many Thanks
Bosun
andywright
« Reply #7 on: November 19, 2007, 08:09:27 pm »
I used cam belt on my Nangee, super glue holds it well, just sand any paint off and stick direct to fibre glass. i use my tug for what it is supposed to be , tugging and pushing, never had a problem with the cam belt. It cuts easily with a stanley knife, just take your time.
portside II
  • tugs at rest
« Reply #8 on: November 19, 2007, 11:44:29 pm »
looks good too Andy ,i have some on my tug 500 from model slipway it aso gives great grip when pushing from an angle.
daz
catengineman
« Reply #9 on: November 20, 2007, 04:45:04 pm »
I used 'O'ring section from an old 'O'ring kit mounted on a thick mouse mat to get the look I wanted and the flexibility I needed to push against a 5 1/2 tonne model ship
R,
bosun
« Reply #10 on: November 21, 2007, 04:54:24 pm »
Hy Guys.
Thanks for the replies, could,nt find any of that rubber mat down at the docks, quite fancy the cam belt idea, and then again I like the look of catengineman,s O ring set up. Will take a look in my local garage tomorrow, Andy I will have to pop down to Cold Knap one day and have a look at your Nangee, went there a few times in the summer, but there were no tugs.
Many Thanks
Bosun
Umi_Ryuzuki
« Reply #11 on: November 21, 2007, 05:31:30 pm »
Here are the first two custom castings, for a client in Washington State, of
the larger bow fender.
The rubber fender for the Tito Neri is shown below them.
And an image with the Tito Neri fender bent over itself.
BarryM
« Reply #12 on: December 21, 2007, 04:38:32 pm »
For the bow fender on a 1:50 scratch-built Yorkshireman. Take two thicknesses of rubber sheet - in this case 1/16th and 1/8th - and glue together. Cut required outline of fender and then mark on scale thicknesses of individual fender blocks. Very carefully cut though thicker rubber without touching thinner sheet. Bend around bow and glue to same. Outer rubber opens up to simulate rubber blocks. The result has survived the knocks of 15 years use.
norry
« Reply #13 on: December 21, 2007, 05:00:03 pm »
     ...Hi Guys...
A very handy item for rubbing strakes is to use Hatch Sealing Tape from a Ship Chandlers...
It is a medium foam with a sticky backing already on it..It comes in different Thicknesses & Widths...
It is also very handy for lining the stand for your boat to sit on a nice soft surface...
            ...All The Best...Norry...
