Author Topic: Motor Mounts  (Read 742 times)
Pat-K
Motor Mounts
« on: November 12, 2025, 07:33:03 pm »
Hi There
Looking for three engine mounts to go in a model MTB (1/32) using Overlander T3536T/06 Brushless engines - what would you recommend please.Also can you recommend a UK based supplier that has stock in and can offer next day delivers - fed up wth being pointed to China and having to wait weeks for delivery
Many thanks
Pat
SailorGreg
Re: Motor Mounts
« Reply #1 on: November 14, 2025, 02:14:42 pm »
I have found these work just fine.  You might have to instal the mount "backwards" to get the motor pointing in the right direction, but I'm sure you can figure that out.
Greg
Pat-K
Re: Motor Mounts
« Reply #2 on: November 15, 2025, 10:55:29 am »
Thank you so much
tr7v8
Re: Motor Mounts
« Reply #3 on: November 15, 2025, 09:28:39 pm »
These mounts are quite flexible, for bigger motors I'd put a bulkhead across the boat and mount to that, either angle the bulkhead to be 90 Deg to the shafts or use double cardens, I did the latter.
Jim
chas
Re: Motor Mounts
« Reply #4 on: November 15, 2025, 11:17:56 pm »
Me too, a bulkhead mounting is a really good way to mount a motor(s) as long as the shaft are correctly lined up together.
Page created in 0.02 seconds with 21 queries.
