Author Topic: Graupner Pollux tug  (Read 15319 times)
J.beazley
  • The building never ends
Graupner Pollux tug
« on: November 17, 2007, 08:50:06 pm »
Ive ordered myself a Pollux tug for a winter project, its the same 1/100 scale as my battleship which is one reason i bought it and the other reason is its a tug so i can pull and push things around.
Out of interest i searched the forum to see if anyone has built it and well i havent seen anything :(
Anyone got one in dry dock or hidden away under a work bench???
Will post some pics of the build when it arrives.
Jay
Re: Graupner Pollux tug
« Reply #1 on: November 17, 2007, 09:08:51 pm »
Small geared motor and careful battery layout!  O0
Ghost in the shell
« Reply #2 on: November 17, 2007, 09:15:24 pm »
for batteries, I sugest a 6xAA type pack, jay, why not build your own superstructure to make it more modern looking?
by the way how much did it cost?
Go Nuclear!  you'll love it
J.beazley
« Reply #3 on: November 17, 2007, 09:34:55 pm »
Cheers for the pics Martin O0
Ive bought the kit and motor unit for under £35 from my local model store (special customer discount included) im not expecting it to be fantastic but it will do what i need it to.
Battery wise i was going to see if i could get 2 Rx packs wired in parallel but we shall see how much space i have in the hull first.
Jay
tobyker
« Reply #4 on: November 17, 2007, 10:06:44 pm »
I fancy one of them, but I think I'd better get one of the four current projects finished first. One does happen to be a 1/96 long grey thing.
offshore1987
« Reply #5 on: December 12, 2007, 10:20:40 pm »
hmm isnt it ment to run on a little lead acid batt?  my local model shop had i might go n get it hehe  :angel:  iv always wanted something small  O0
good luck
J.beazley
« Reply #6 on: December 12, 2007, 10:25:22 pm »
Made a start on my Pollux yesterday pics to come but its a nice litttle kit,
im going to use a lead acid in mine once i get that far.
Jay
Big Ada
« Reply #7 on: December 13, 2007, 05:56:19 pm »
Make a barge and put the battery in that!
    ;) Len  ;)
offshore1987
« Reply #8 on: December 14, 2007, 01:08:17 am »
12 v lead acid?  :D {-) ojoj lol
cant wait to see some more pics  O0
« Reply #9 on: December 14, 2007, 09:00:37 am »
You can get some quite small lead acid (gel cell batteries), used in Alarm back-up systems.
RS:
Description NP sealed lead acid battery,12V 1.2Ah
Capacity 1.2Ah
Voltage 12V
Terminal Type Faston 4.8x0.8
Operating Temperature -5 → +35°C
Weight 0.57kg
Battery Type Lead Acid NP
Depth 97mm
Height 54.5mm
Maximum Charge Current 0.30A
Maximum Discharge Current-mAHrs 40A
Width 48mm
or    http://www.component-shop.co.uk/html/lead-acid.htm
l
ray123
  • shuswap tugboat
« Reply #10 on: December 14, 2007, 03:48:11 pm »
hello guys i used to have a pollux tug i put normal r/c gear in a 6v 1amp lead acid    it run for 2hours!   i did tug towing with it! O0 chucked it in the sea it was a great little boat  O0 other club members said i should get another one & ill have a pair of polluks  {-)
J.beazley
« Reply #11 on: December 14, 2007, 06:34:57 pm »
Come to the conclusion i want to make a Kort nozzle for my little tug, any ideas on how to go about it ???
I was thinking of using a piece of plastic pipe a little larger then the 30mm prop would this do or would it need to be tapered in any way???
will post some pics up when i find the camera
Jay
« Reply #12 on: December 14, 2007, 06:41:55 pm »
J.beazley
« Reply #13 on: December 14, 2007, 06:50:01 pm »
Good thinking but dont think i can make a becker rudder that small ::) Will try a bit of plastic pipe and see where that gets me.
steerable kort, round bit of pipe attached to the rudder post instead of the blade style rudder they supply.
worth a bash i think.
Jay
« Reply #14 on: December 14, 2007, 07:06:28 pm »
I was think more of a simple tube, as you say Jay, doesn't need to be tapered, your not going to win any national prises with a Pollux... well maybe, and fix a single plate rudder to the tube and turn the whole lot as the rudder!
J.beazley
« Reply #15 on: December 14, 2007, 07:19:23 pm »
that pic is EXACTLY what im after do they come in miniture??
going on that pic i think its the best way forward, get a lot more control and thrust aswell.
Jay
Big Ada
« Reply #16 on: December 15, 2007, 05:55:16 pm »
Try a Fishtail Rudder, have a look on MB Forum.
Len.O (see a sketch on my gallery)   :embarrassed:
Wiggy
« Reply #17 on: December 15, 2007, 11:55:53 pm »
Hi Jay,
   Built the Revell 'Lucky' kit and decided to be stupid and motorise it so needed an alternative form of steering as it was hard to use the original design of rudder. I  made a Kort out of some 12mm. brass strip bent round a dowel, about 25mm. and then soldered with a thin butt strip into a Kort shape. Drilled it and again soldered a piece of thin brass rod, about 3/16" for the stock and a brass tube sleeve through the hull. The reason the nozzle is so large is that a 25mm. prop. was far too powerful and changed it to a 20mm. one but still works great.
Paul.
J.beazley
« Reply #18 on: December 16, 2007, 01:51:23 pm »
Right as promised some pictures of the build (found the camera)
Found some plastic pipe thats got a 34mm ID which is perfect for the pollux as a kort nozzle, if i didnt know better it looks like it was supposed to come with it.
need to cut the rudder post down and epoxy it to the Kort then its good to go.
Will post more as i build, i think some paint might be on the cards next. mmmm what colours to do her in  ???
Jay
J.beazley
« Reply #19 on: December 16, 2007, 08:17:07 pm »
Need a bit of advice from you tug boys.
Running the pollux on the geared motor would it be able to tow?
Reason i ask is i am going to reinforce the inside of the superstructure behind the tow hook, im also going to fix the superstructure down with bolts or dowel with split pin.
Jay
offshore1987
« Reply #20 on: December 16, 2007, 11:36:58 pm »
looks ace  O0 cant wait to see the rest of this build  ;D really suit the little tug indeed, how is the best way to do the rudder? i was thinkin maybe to go all the way up on the deck to gain some room? or is it not cramped inside?
J.beazley
« Reply #21 on: August 04, 2008, 05:12:39 pm »
Finished model apart from tow hook which is under construction.
Goes rather well with the 6v 4ah SLA in her and sits rather well on the waterline too, finished pics aswell as a vid that Shipmate60 took when testing his 12foot battleship.
Vid before i painted and played with the upper works.
http://smg.photobucket.com/albums/v479/jayimageservices/?action=view&current=Picture032-1.flv
Jay
offshore1987
« Reply #22 on: August 14, 2008, 04:59:09 pm »
ace :) the vid is great lol  O0
TheLongBuild
  • Build em, and play hard..
« Reply #23 on: August 12, 2012, 08:33:46 pm »
Wow 730 days since the last Post,   :}
Jay is the video still available to see as I am trying to get mine ready for Haydock ?.
« Reply #24 on: August 12, 2012, 08:38:21 pm »
                  Our Vaults are worth exploring     O0
ken
Page created in 0.375 seconds with 17 queries.
