Author Topic: HMS Manxman  (Read 1621 times)
Rob47
HMS Manxman
« on: September 05, 2026, 03:00:18 pm »
I am trying to find out the exact issue of model boats the build article by Glynn Guest of HMS Manxman appeared. AI has been useless  <*<  normally not to bad
I will finish this model
GG
Re: HMS Manxman
« Reply #1 on: September 05, 2026, 03:55:22 pm »
Bob,
     Boy, that's something of an oldie! Try Model Boats issue Sept 1989.
I have fond memories of this model which might still exist?  It was my first model not to be powered by dry cells, it used a 6 volt 4 Ah accumulator.  This drove a Monoperm Super Special motor connected to a P30 propeller.  Like its namesake it would zip around the lake at 5-6 ft/sec which made sailing it with a single channel rudder only RC system quite interesting.  Life was less stressful when a 2 function RC system was installed!
Glynn Guest
Rob47
Re: HMS Manxman
« Reply #2 on: September 05, 2026, 04:47:23 pm »
Glynn. Many thanks for that, will give it a whirl and see
Rob47
Re: HMS Manxman
« Reply #3 on: September 05, 2026, 04:53:59 pm »
That issue has HMS Ganges as plan is that the issue?
Re: HMS Manxman
« Reply #4 on: September 05, 2026, 05:46:38 pm »
If I might butt in!
HMS Ganges was the pull out plan in the September 1989 issue.
HMS Manxman was Glynn's Feature Plan. The article was in the magazine but you needed to buy the plan separately It is still available from Sarik Hobbies:
https://www.sarikhobbies.com/product/hms-manxman-mm1438/
Hope this helps.
Rob47
Re: HMS Manxman
« Reply #5 on: September 05, 2026, 06:28:43 pm »
Colin thanks so much. It?s the article I want ,plan not an issue
Rob47
Re: HMS Manxman
« Reply #6 on: September 05, 2026, 06:48:34 pm »
Found it on well known auction site, went to buy it told seller on holiday times might be longer, tried to check out told seller is taking a break. So square one again {-) {-)
Rob47
Re: HMS Manxman
« Reply #7 on: September 06, 2026, 06:47:44 pm »
He back, I bought so let?s hope
Rob47
Re: HMS Manxman
« Reply #8 on: September 11, 2026, 07:54:19 am »
Well Magazine arrived,good read and interesting to see names of shops long gone and also the style of articles and layout. Biggest surprise though was looking at some event images and there were two pictures of an officer I used to serve with, small world.
Page created in 0.014 seconds with 20 queries.
