Pro Peak Sigma Mains & 12volt Charger
New In this mains and 12 volt charger allows you to charge Ni-Cads / Ni-Mh / Lead acid / Li-poly and Li-ion .
So you can charge at home of the mains or at the field or lake on the 12 volt system .Making this a very versatile system charging most of today's battery types
Spec's
input Voltage 11~15volt DC to 100~240Ac
1~14 Cells Nickel Cadmium
1~14 Cells Nickel Metal Hydride
1~5 Cells Lithium-ion/Lithium Polymer
1~6 Cells Lead Acid
Charge Current 0.1~5amp in 100ma steps
Discharge current 0.1~1amp in 10ma steps
Auto Limited to 5w maximum )
Trickle Charge Current 0~200ma
Charge Termination Zero Delta V , Peak Detection for Ni-Cd /NiMh
Constant Current Constant Voltage for lead Acid and Li-po/lon
Cycling: Charge to Discharge ,Discharge to Charge
Display: 2 Line LCD Screen Blue backlit
Voltage Monitoring :Using EQ-6 + Balancer only
http://www.westbourne-models.com/#4250X0
