Author Topic: Revell Flower class corvettes  (Read 12408 times)
guard_jamie
« on: June 22, 2006, 04:42:49 pm »
I must first admit to being somewhat out of my depth in this field of modelling- I'm a railway man myself! But after watching The Cruel Sea I simply had to have a Corvette, and I got a Revell one. I haven't made much of a start, but I was wondering if anyone could give me some really detailed information on motors, batteries, props, RC equipment, and all the other related paraphernalia that has to be included if I wish to make it sail (and I've never seen the point in a model that doesn't work!) What you would recommend, where to put what in the boat, any easy yet fun extras I could add, what to use as ballast. Basically, 'the low down', in its entirety!
Thank you,
Jamie Green
"The boy stood on the burning deck, whence all but he had fled. Twit".
RickF
Re: Revell Flower class corvettes
« Reply #1 on: June 22, 2006, 04:58:04 pm »
Jamie - "Voyager" has just started building an R/C Revel "Flower" on the "Your Builds" board - Check it out!
Rick
guard_jamie
« Reply #2 on: June 22, 2006, 06:18:31 pm »
Painfully elementary question that I'm very embarassed to ask- how on earth do you stop water getting up the prop shaft? ???
Youngat65
« Reply #3 on: June 22, 2006, 06:37:01 pm »
Stick some grease in it or I use motor-cycle chain lube some may say that useing grease causes a lot of drag but so what we are not talking fast electrics here
        Bob B
funtimefrankie
« Reply #4 on: June 23, 2006, 07:13:59 pm »
« Reply #5 on: June 26, 2006, 11:51:50 am »
Regarding the water up the proptube - I agree with the greasing, but make sure that you can service it (ensure that yoiu can get the rudder out of the way without demolishing the back end of the boat).  I sail mine in a salt water lake with plenty of silt and geese, after several years and about 500 real miles, I had to change the prop shaft assembly, the shaft was badly worn in the area of the bearings, letting water up the tube, and the brass tube was corroded.
« Reply #6 on: June 26, 2006, 09:40:03 pm »
And ballast her deep, I have seen so many bobbing over the waves and looking very toy-like.
When they are deep in the water they look superb and handle better.
Daryl
« Reply #7 on: June 26, 2006, 09:55:57 pm »
I agree with Shipmate60. I used 11kg of ballest in mine to get it to the right level.
Daryl
« Reply #8 on: June 27, 2006, 11:26:43 am »
Daryl
Are you talking about the Revell Flower class?  Its a 1/72 scale model, and the correct weight is 6 pounds, give or take a very few ounces.  11Kg would be disappointing.
Daryl
« Reply #9 on: June 27, 2006, 12:36:54 pm »
Why disapponting????? I ballasted it to a photo I had of the real thing. Works for me. This photo was taken at Kingsgate Park Yate a few months ago. The inside of the hull is lined with GRP. When you convert pounds to kilos it works out at about 5lb of ballest then add about 1lb for motor and battery and there you have the result in the picture.
Daryl
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
« Reply #10 on: June 27, 2006, 12:48:29 pm »
Daryl,
I reckon you could probably do with another pound these sort of ships were not supposed to ride the but cut through the water, nice model and all...
Roy
ron h
« Reply #11 on: June 27, 2006, 12:49:43 pm »
Daryl, lovely looking model on the water, but you have your lbs and lilo,s mixed up, its 2.2 lbs to 1 kilo, what he ment about dissapionting at 11kilo,s which is 24.2 lbs it would sink under the water. ;D ;D
Daryl
« Reply #12 on: June 27, 2006, 12:59:30 pm »
Hi Ron,
your right, wrong conversion!!! sorry folks.
I put most of the ballest towards the front to try to improve the sea keeping which to some extent worked.
I have just had a look and its got a 5 Kilo weight in it plus battery etc. Which makes it about 6lb.
11kg is fine for a 1/48 scale but as you said on the Revell it would sink it. The shade of the colours is brighter than the RN Western Approaches scheme in that I have seen several near misses and one sinking where the camoflauge did exactly what it said on the tin. So I thought I would make it a bit more obvious.
Daryl
dannymax
« Reply #13 on: June 27, 2006, 05:09:29 pm »
the lb ands kilos in these posts are all over the place......454g = 1lb so basically to make it easy a kilo is around 2lb
« Reply #14 on: June 27, 2006, 05:12:24 pm »
5Kg is about 11Lbs (1k = 2.2Lbs)
Doug
Youngat65
« Reply #15 on: June 27, 2006, 06:07:47 pm »
Wouldn't be having all these problems with weight if we just stuck to good old english lbs if your working imperial stay imperial if you are working in metric stay in metric saves a lot of messing about with convering one to another.
ron h
« Reply #16 on: June 27, 2006, 06:56:17 pm »
I just put 30lbs of lead in mine, and a few batteries, she is 7ft long ::) ::)
Daryl
« Reply #17 on: June 27, 2006, 09:33:55 pm »
Umm.... glad to see its all getting confused, that way I can spread the balme!!!!
Now I am at home I can clarify what I have in there, when I got the confusion going I was at work trying and failing to do three things at once and mucking up all of them!
What I have in there is a bar of lead/tin ( ratio 60-40) 1 inch wide, 1inch high and 16 inches long. I'll leave you all to work out the weight.
Can't find Carol Vorderman when you want her.........
Daryl
« Reply #18 on: June 28, 2006, 07:46:14 am »
Lead is much denser than tin (which is quite expensive). If it is tin sell it and buy a new boat ;D ;D ;D
Doug
Daryl
« Reply #19 on: June 28, 2006, 08:49:55 am »
Firm I work for was chucking out a flow solder machine and I had the left over bars, which would have ended up at the reclamation centre. As you can see from the photo it works fine.
Daryl
« Reply #20 on: June 28, 2006, 03:18:19 pm »
Nice one, Daryl
I "ballasted" mine with a 12v 3AH battery as far back as I could in the forecastle.  This wasn't quite as far back s I would have preferred as the local model shop didn't have a prop shaft shorter than 10", so I wound up putting about 8oz of lead in the stern to trim it.  You are right about the paint job - the pale western approaches job does have a habit of vanishing in overcast conditions with a bit of a dapple on the water, especially if it is not leaving an obvious wake.
Daryl
« Reply #21 on: June 28, 2006, 04:05:02 pm »
Hi Malcolm,
Did you have a problem with the deck stringers? I went by the instructions and found the deck was 6mm to wide. I ended up trimming the deck as by this time I had lined the hull with grp tissue. It appears that in my kit the stringers are to short, a friend of mine who built the Matchbox version did not have this problem so I wonder what have Revell done to muck it up? A rather puzzeling.
I had to do the same as yourself as I glassed in the solder bar to far forward and ended up putting some lead sheeting left over from a roof replacement to balance the thing.
Daryl
« Reply #22 on: July 03, 2006, 07:22:15 pm »
Hi Daryl
The deck beams on mine all fitted easily.  Thats on the 6 year old one.  The new one had one a bit long, but it was just a few strokes of sandpaper.  I never felt the need to line with GRP - the plastic is strong enough.
Daryl
« Reply #23 on: July 04, 2006, 09:21:38 am »
I lined mine with grp as when I put it in the bath I had a small leak from one of the side joins. So with the traditionial use a sledgehammer to crack a nut idea, I lined all of it with grp and the used it to fix the solder bar in.
Good kit, I used John Lamberts excellent book to detail mine, well worth getting.
Daryl
shark bait
« Reply #24 on: July 05, 2006, 12:46:42 pm »
I have seen lots of variations in the camuflage schemes used on these corvettes. Has anyone got an idea where can i get a guide as to what was used in various theatres and by which ships. My model is HMS Bluebell if that helps. I would like to get it authentic but without blatently copying another modellers creation.
Any ideas or pointers would be welcome.
PS The guy who had the corvette at the Northern Boat Show had a wonderful boat. It looked great and got me thinking i could improve on mine.
thanks
