Author Topic: Twin Props Fitting "A" Frames How?  (Read 9731 times)
banjo
Re: Twin Props Fitting "A" Frames How?
« Reply #25 on: December 19, 2007, 12:16:41 pm »
Here we are with a pic of the brass distance strips in place,   This should keep the shafts parallell
 O0
HS93 (RIP)
  • I cannot spell , tough
« Reply #26 on: December 19, 2007, 12:28:37 pm »
Bet your glad you decided to go for twin set up.   :D
Have you joined
http://groups.yahoo.com/group/firefloat/
Peter
banjo
« Reply #27 on: December 19, 2007, 12:45:02 pm »
OVERJOYED!!!!!!!!!!
 O0
banjo
Re: Twin Props Fitting "A" Frames Like this?
« Reply #28 on: December 21, 2007, 08:37:38 am »
where I am so far:-
Utilizing all of the above hints and tips I have installed the prop shafts and A Frames.
The legs of the frames were secured inside the hull using sections of tube pushed down over the legs and then epoxied into place using "Z-Poxy"
I would have drilled and pinned them but the appropriate drill suddenly went blunt!!  The tube sections were a desperate alternative which has worked as well. (I hope)
Thanks to all,
 O0
PS
The "E-poxy" is taking a long time to cure, where it is in a "lump" over the "A" Frame fixing?
HS93 (RIP)
« Reply #29 on: December 21, 2007, 09:28:03 am »
  See it wasn't that hard.!!! :D   >>:-(  ;)
Peter  :angel:
Looks good by the way
banjo
« Reply #30 on: December 21, 2007, 09:37:04 am »
Thanks to all the help, it wasn't.....
Its all in the planning...
Get that right and your 85% there..
 O0
spongie
« Reply #31 on: August 10, 2015, 09:49:23 am »
Dragging an old topic back from the dead...
I'm about to do this for the first time ever. SERIOUSLY hugely helpful posts folks
Page created in 0.097 seconds with 22 queries.
