Author Topic: Twin Props Fitting "A" Frames How?  (Read 8180 times)
banjo
Re: Twin Props Fitting "A" Frames How?
« Reply #25 on: December 19, 2007, 12:16:41 pm »
Here we are with a pic of the brass distance strips in place,   This should keep the shafts parallell
 O0
HS93 (RIP)
  • I cannot spell , tough
« Reply #26 on: December 19, 2007, 12:28:37 pm »
Bet your glad you decided to go for twin set up.   :D
Have you joined
http://groups.yahoo.com/group/firefloat/
Peter
banjo
« Reply #27 on: December 19, 2007, 12:45:02 pm »
OVERJOYED!!!!!!!!!!
 O0
banjo
Re: Twin Props Fitting "A" Frames Like this?
« Reply #28 on: December 21, 2007, 08:37:38 am »
where I am so far:-
Utilizing all of the above hints and tips I have installed the prop shafts and A Frames.
The legs of the frames were secured inside the hull using sections of tube pushed down over the legs and then epoxied into place using "Z-Poxy"
I would have drilled and pinned them but the appropriate drill suddenly went blunt!!  The tube sections were a desperate alternative which has worked as well. (I hope)
Thanks to all,
 O0
PS
The "E-poxy" is taking a long time to cure, where it is in a "lump" over the "A" Frame fixing?
HS93 (RIP)
« Reply #29 on: December 21, 2007, 09:28:03 am »
  See it wasn't that hard.!!! :D   >>:-(  ;)
Peter  :angel:
Looks good by the way
banjo
« Reply #30 on: December 21, 2007, 09:37:04 am »
Thanks to all the help, it wasn't.....
Its all in the planning...
Get that right and your 85% there..
 O0
spongie
« Reply #31 on: August 10, 2015, 09:49:23 am »
Dragging an old topic back from the dead...
I'm about to do this for the first time ever. SERIOUSLY hugely helpful posts folks
