Author Topic: type 21 funnel  (Read 4784 times)
djrobbo
type 21 funnel
« on: December 16, 2007, 05:11:23 pm »
Hi guys........ allways have a problem with getting funnel shapes dead right..... i have just bought a type 21 hull 1/72 and would like to know ..........
        does anyone do a funnel for a type 21 in 1/72....??   dont really care what its made of..
             hope you can help
                  regards.....bob. O0
Martin13
Re: type 21 funnel
« Reply #1 on: December 16, 2007, 07:20:47 pm »
Bob,
APS Models in Australia - $42 Aus
Martin doon under
Re: type 21 funnel
« Reply #2 on: December 16, 2007, 07:36:20 pm »
APS do quite a lot of fittings too.
djrobbo
Re: type 21 funnel
« Reply #3 on: December 16, 2007, 07:45:17 pm »
Cheers guys...looks like aus it is.....brother in law lives in melbourne might see if he can help ..
             thanks again
             regards...bob.
djrobbo
Re: type 21 funnel
« Reply #4 on: December 17, 2007, 12:28:56 pm »
Hi martin got the p.m will probably try that route and see what happens thanks for that. O0
         Next question , sombody has suggested pink foam ......vas ist das ???? haven't come across that stuff before...and won't i still have to try and get the shape right.
                 maybe me being fffikk . ( notice cockney spelling of thick which uses three f's )
                       regards...bob.
Re: type 21 funnel
« Reply #5 on: December 17, 2007, 12:38:01 pm »
Extruded foam sunbeam! The stuff we glider guiders used for foam cores AFTER expanded poly. Yep you still have to get the shape right, but it can be cut and sanded and doesn't crumble like EP.I said pink cos that's the colour of the slab I got, but it can be blue or green. Pink foam is the new "green" blue foam if yer see what i mean. :kiss:
djrobbo
Re: type 21 funnel
« Reply #6 on: December 17, 2007, 02:18:28 pm »
I take it from that i have to go into a shop that does those noisy smelly flying thingy's to buy some ?
         does it glue up with p v a or do you need a special adhesive ?
         will give it try when i can find a shop near me that sells the aforementioned article .
               thanks for the tip
                    regards.....bob.
Re: type 21 funnel
« Reply #7 on: December 17, 2007, 05:11:13 pm »
Sorry for delay Bob, SWMBO dragged me out by the tinsels, (Bl---y Christmas again, Hum babag) You can get this foam from a local construction site, scrap bits or from Sheffield Insulations in sheets, it was mentioned on a thread before, when Holmsey wanted a block for something. You can cut W--g cores out of it , use it to make a "Plug" for a glass hull, but I've also used it in place of block balsa. Can be cut with a knife, sawblade, hot-wire or soldering iron at a pinch, can be sanded and plated with paper or epoxy resin. S.I. are a national firm, my lumps of foam were a sheet with a damaged corner, cost "A DRINK"  ;) Know what I mean O0
Yes it glues with PVA or Aliphatic or araldite but keep glue clear of sanding edges.You could also make deckhouses with it.
djrobbo
Re: type 21 funnel
« Reply #8 on: December 17, 2007, 08:08:43 pm »
Sounds like the very stuff for me , i like finding out what i can do with new materials . you know what us old farts are like , use what youv'e always used
            thanks for that anyhoo
               regards....bob.
Page created in 0.017 seconds with 20 queries.
