Author Topic: 2-way Switcher  (Read 2410 times)
6705russell
2-way Switcher
« on: December 26, 2007, 09:20:01 pm »
I need to control a pump to work in both directions but dont want to put a speed controller in circuit, as anybody used a two way switcher controlled /powered off the receiver/main battery or where to get one?
Many thanks
Russ
Stan
Re: 2-way Switcher
« Reply #1 on: December 26, 2007, 09:51:32 pm »
Hi Russ, Contact Dave at Action  Electronics they make a two function  switcher that will turn on the pump and allow it to be run in both directions. I have used this  unit in my carrier to operate the rear aircraft lift. I think the max current this unit will take is 3 amps  please contact above for info hope this helps.
Stan. O0
6705russell
Re: 2-way Switcher
« Reply #2 on: December 26, 2007, 10:39:56 pm »
Thanks Stan, what carrier are you building?
Russ
Stan
Re: 2-way Switcher
« Reply #3 on: December 26, 2007, 11:27:19 pm »
Hi Russ,  U S S Gambier Bay  at 1/96 scale. Model details lenght 64 in  about 14 in across flight deck  and from keel to highest point on radar about 18in. Gambier Bay was  a Casablanca  class WW2  Escort carrier  CV 73 see was the only U S carrier to be lost to enemy gun fire.If your interested please e mail details via mayhem and will send some picks.
Stan  O0 O0
2772e
  • Simon
  • The Sea Shall Not Have Them
Re: 2-way Switcher
« Reply #4 on: December 27, 2007, 09:28:48 am »
Russ,
I have been testing (to destruction) the two way switcher from Action in my tug, i use it for the bow thruster. Has full adjustability and works on various power supplies.
Works a treat and saves all those messy microswitches and additional ESC's.
I will also run one for the fire pumps when i get to that stage
Highly recommended.
BW
Simon
Rubbin is Racin!
