Author Topic: Dulux/Humbrol Deck Wood Finish - colour matching/laquer/finish  (Read 2484 times)
polaris
« on: January 02, 2008, 07:11:41 pm »
Dear All,
I have had need recently to restore/renew a section of planking on my 1:96 HMS Belfast, with the essential requirement of matching in new wood to the existing deck colour/finish; a rather daunting task, and in principal nearly impossible to get perfect without renewing everything. However, after much thought and some experimentation a 95% match has been achieved with the new wood which has proved very satisfactory, and with only a 'simple wash' to get it 'right'.
The new plywood (basswood), needed to match the existing light golden yellow colour (old/worn well applied lacquer or varnish). The finish to match was old and had been 'weathered' in a loft for about nine years. All decks had been prev. washed during the Summer with numerous applications of an alternate surgical spirit and warm Fairy Liquid rinse (all 'scrubbed' with a fine paint brush) - there was a light to medium coating of a sticky greasy substance to get off parts off sections of the deck, and the Surg. Spirit was needed to remove it (did not use White Spirit as thought it too 'rough').
After browsing all sorts of wood stains in a shop with a good selection of different mfrs. prods., I arrived at Natural Beech (Dulux - Woodsheen, Interior/Exterior). The product as in the tin was still a little too dark to match the 'golden colour', but experimentation thinning down with White Spirit resulted in a 'nearly but not quite' match. It was realised (anticipated), that the addition of colour was necessary. The colour chosen was Humbrol Matt 74. By adding a touch of 64 in stages, an as near as possible match has been achieved. After looking at the new finish, I then decided to 'wash' all the wood decks with the same dilute solution, and a better 'scale' colour has been achieved - what I would call a proper 'natural salt whitened scrubbed wood finish'. The finish has dried perfectly, including the 'over-painting' of the original worn stain/varnish. All that remains is to cover the new wood section with a coat of thinned satin lacquer so to obtain a light sheen - which will match in with the surrounding deck.
The point of all this is that Dulux Woodsheen wood stains can be used in conjunction with Humbrol colours - don't know about Revell, but if Humbrol is ok then I am sure the latter will be - since Humbrol and Revell seem to mix together - laquers anyway. As a general compatibility test, I deliberately left some of the mixture in the mixing bowls (covered with cling film), to see how it managed, and, even after 24 hrs., by adding a little White Spirit, the solution was rejuvenated and usable. I believe this to be sufficient proof of the compatibility of these two makes/types of paint, and much is possible with the different Dulux Woodsheen stains and the many Humbrol colours.
Hope this might be of use to someone.
Regards, Bernard
Re: Dulux/Humbrol Deck Wood Finish - colour matching/laquer/finish
« Reply #1 on: October 27, 2012, 01:02:10 am »
Jerry C this morning spoke about white spirit....here is the WIKI speal on this fluid......
Where I got mixed up is that in OZ it is termed as turps or
mineral turpentine......and >>:-( not to be confused grog......
Being petroleum based I am surprised it was incompatible with a wood stain.......Derek
___________________________________________________________________________________________________________
White spirit (UK)[note 1] or mineral spirits (US),[1][2][3] also known as mineral turpentine, turpentine substitute, petroleum spirits, solvent naphtha (petroleum) or Stoddard solvent,[4][5] is a paraffin-derived clear, transparent liquid which is a common organicsolvent used in painting and decorating. In 1924, Atlanta dry cleaner W. J. Stoddard worked with Lloyd E. Jackson of the Mellon Institute of Industrial Research to develop a less volatile dry cleaning solvent as an alternative to the petroleum solvents in use. Dry cleaners began using the result of their work in 1928 and it soon became the predominant dry cleaning solvent in the United States, until the late 1950s.
It is a mixture of aliphatic and alicyclic C7 to C12 hydrocarbons with a maximum content of 25% of C7 to C12 aromatic hydrocarbons. A typical composition for mineral spirits is > 65% C10 or higher hydrocarbons,[6]aliphatic solvent hexane, and a maximum benzenecontent of 0.1% by volume, a kauri-butanol value of 29, an initial boiling point of 65 °C (149 °F), a dry point of approximately 69 °C (156 °F), and a density of 0.7 g/ml.
Stoddard solvent is a specific mixture of hydrocarbons, typically > 65% C10 or higher hydrocarbons.[7]
White spirit is used as an extraction solvent, as a cleaning solvent, as a degreasing solvent and as a solvent in aerosols, paints, wood preservatives, lacquers, varnishes, and asphalt products. In western Europe about 60% of the total white spirit consumption is used in paints, lacquers and varnishes. White spirit is the most widely used solvent in the paint industry. In households, white spirit is commonly used to clean paint brushes after use.
