Gents,
When I did this, I just made up enough dry fit planks for about two or three rows. There is no rush, they will still stick after about ten minutes drying time. I did this most probably over a two or three week period.
I would just try it on a bit of scrap first, just so you can get a feel for it. If you want plank spacing on a deck I would pop a bit of plasticard or litho plate every so often along the joint, and pull it out as soon as the plank is in position, then go straight onto the next plank. Don't worry if you get any on the top surface, it just sands straight off, or you could use a scaper. If you want to simulate caulking, this can be put into the semi set glue along the edge of the plank before the next one is butted up to it, again you will have plenty of time.
Don't rush it, it's not going to get up and run away overnight, it will still be there next time you come to do some.
I have only ever used el cheapo gunwash cellulose thinners, about £8 a gallon last time I bought some. I mix it up in a small sealable container (35mm film case), and just put a spot more thinners in when it starts to thicken up with evaporation. Stirred not shaken. A solid brush soon softens up after coming into contact with the glue again. Then throw the remnants and brush away when you have finished at the end of the job.
If you want to try acetone, try it on a bit of scrap, and come back an hour later to see if you can peel the planks off easily, if not, you've cracked it.
I didn't use dollops of the stuff, just a very thin layer on each part. If you put too much on you might have trouble with the thinners attacking the styrene too deeply, instead of just the surface layer, this would cause a much longer drying and fixing time.
For prep, just flat the surface of the styrene down to a matt finish, this will give a key for the contact adhesive to bond on to.
I hope this helps in your endeavours.
