Author Topic: schottel drive  (Read 4898 times)
boatmadman
schottel drive
« on: January 26, 2008, 05:12:08 am »
Can anyone tell me what 'footprint' a schottel drive requires inside a hull, including the space required for the motor and servo?
Re: schottel drive
« Reply #1 on: January 26, 2008, 09:43:03 am »
see Stav's super springer
stavros
boatmadman
Re: schottel drive
« Reply #2 on: January 26, 2008, 01:06:21 pm »
Thanks Stav.
 Could you possibly give me some dimensions? Like length and breadth of the whole installation?
Reason is, I am working on an idea and need to get a feel for how much space I need for two of these things.
Re: schottel drive
« Reply #3 on: January 26, 2008, 06:35:20 pm »
inc motor 160mmx100mm thtas the area you need as for height my drive is approx 50mm high hope this helps
boatmadman
Re: schottel drive
« Reply #4 on: January 26, 2008, 08:27:11 pm »
Just what I need Stav, thanks.
funtimefrankie
Re: schottel drive
« Reply #5 on: January 27, 2008, 07:44:15 pm »
The black Graupner ones are a fair bit bigger, if you need the sizes of these let us know.
boatmadman
Re: schottel drive
« Reply #6 on: January 27, 2008, 10:50:42 pm »
That would be helpfull, thanks FFF.
funtimefrankie
Re: schottel drive
« Reply #7 on: January 28, 2008, 10:49:50 am »
From the front of the motor to the back of the drive is about 25cms you need about 7cm head room, ie from hull bottom to under deck. They are about 6cm wide.
The servo is mounted with the drive, unlike the Marx one, You can just see it at the rear end under the gear wheel, which is mounted directly on the servo.
