Author Topic: Seaport Workboat RTR Alterations  (Read 33458 times)
Re: Seaport Workboat RTR Alterations
« Reply #25 on: February 13, 2008, 09:46:30 am »
Thanks for the comments chaps.  :)
Mr Andy
« Reply #26 on: February 13, 2008, 07:48:44 pm »
That is brilliant it's only looking at the stern and Kort I realised what it was.
Andy. O0
Edward Pinniger
    • Plastic Ship Kit Previews
« Reply #27 on: February 17, 2008, 03:18:49 pm »
Great work!  O0 You've completely transformed this RTR into a very nice steam tug model.
(Looks like you've had a very similar idea to me, but have made a much better job of it! I'll post some more photos of my build soon, though)
bbdave
« Reply #28 on: February 21, 2008, 06:15:39 pm »
Excellent! i just bought one of these but had only planned to change the innards i'm not so sure now O0
Did you seal the hull and deck or glue the joint?
« Reply #29 on: February 21, 2008, 06:38:07 pm »
Just screwed it back together using the existing seal. Haven't been well enough to try it on the lake yet, just the pond in the garden, so will have to see if I need to do more. :-\
« Reply #30 on: April 06, 2008, 04:04:09 pm »
Today was the day for the maiden voyage having now finished the wiring [done away with the BECC] and re routed the aireal up the inside of the stack.
You might have noticed today was not a good day for an idiot like me with emphysema to be sitting in a wheelchair alongside a lake in The New Forest.
So the maiden voyage was in a poly box in the back garden after the snow thawed.
Had her running for an hour on 6V and all well. Very lively and lovely and dry inside.
Roll on better weather.
Roger in France
« Reply #31 on: April 06, 2008, 04:16:58 pm »
She is looking good, Richard. You should have been here with me for your maiden voyage today, clear blue sky and warm sunshine.
I am shortly off sailing a model yacht as the wind has now picked up.
Roger in France.
« Reply #32 on: April 06, 2008, 04:35:52 pm »
Clear blue skies and sun here now Roger just to damned cold for my breathing, enjoy your sail. O0
« Reply #33 on: April 06, 2008, 05:37:01 pm »
Dicky oh Wise one, Chinese proverb say When the tide rises, boats float higher - does the tide rise in your test tubby .... you cheaty ... floaty boaty in boxy  :D :D :D
Looks good mind Dicky....  O0 O0
john
« Reply #34 on: April 20, 2008, 02:29:38 pm »
Well beautiful day, sunny and warm, time for a maiden voyage.
All went well though she rides a tad high so will have to add a bit more ballast.
Prop joint a bit noisy but I can live with that.
Very nippy on 6V and very manouverable too.
« Reply #35 on: April 20, 2008, 05:31:23 pm »
Tug Dicky rides the waves
number-1
« Reply #36 on: April 21, 2008, 10:01:42 pm »
great looking tug you have there, you mention its very manoeuvrable, I'm looking for a new project for scale steering competions, do you think this would be suitable? whats the length/beam? thanks for any replies. Les
« Reply #37 on: April 21, 2008, 10:04:51 pm »
Maneuverable when going ahead, rubbish when going astern  O0
tolnedra
« Reply #38 on: April 21, 2008, 10:35:26 pm »
Hi Richard,
You haven't changed the prop/kort nozzle, have you? Mine isn't too bad astern, but you have to give it time to react.
Danny
« Reply #39 on: April 22, 2008, 08:16:02 am »
No I kept the kort nozzle and prop Danny.
Got a lot of cavitation going astern, but I think it might have been riding a bit high in the water so I have added some more ballast and will try again.
Ghost in the shell
« Reply #40 on: April 22, 2008, 03:06:12 pm »
My Miranda does that where identical ~Gemini does not, so a lil weight in her rear end will do it
Go Nuclear!  you'll love it
rwalker
« Reply #41 on: May 10, 2008, 11:14:38 pm »
Here's that motor mount pic that Weeds asked for. It may look different than what you have, this is the Hen Long Work Boat. As you can see, a hotter Mabuchi can motor will fit nicely into the intended mount. HOWEVER! This image is possible because I had to open it up again.
It seems two things happened:
1. The motor loosened from its mounting screws
2. The resulting friction against the mount experienced by universal heated up the motor shaft  u-joint and the hole thing came loose from it.
It seems that with a stronger motor, the friction fit of the stock u-joint is inadequate for prolonged runing....or was the sudden reverse move by the Cub Scout at the controls the cause? Who knows, but I'm going to upgrade the u-joint to something proper.
And tighten those screws down with Loc-Tiite!
Damien
« Reply #42 on: May 17, 2008, 08:07:37 am »
Richard,
What approx scale are these tugs ? I'm  trying to work out dimensions for superstructure, masts etc. I've filled all the imperfections in the hull and deck, and ready to tackle the cabin/deckhouse etc.
Damien.
« Reply #43 on: May 17, 2008, 09:49:36 am »
Hi Damien I worked mine on a 1:48 scale more or less, the crew are 1:50. ;)
Damien
« Reply #44 on: May 17, 2008, 11:51:23 am »
Thanks Richard, I'm going to base mine loosely on MT Lorraine, an Aussie tug based in Queensland.
  Lorraine: Specifications
General Specifications
Survey (QLD)   USL 2B (4 persons), USL 2D (6 persons)
Length   15.3 metres
Beam   4.7 metres
Draft   2.0 metres
Displacement   47.8 tonnes
Bollard Pull   7 tonnes
Fuel Cargo Capacity   20,500 litres
Water Cargo Capacity   2,000 litres
Machinery & Equipment
Main Engines   2 x 300 hp Cummins NT855
Generator   1 x 12 kva Nissan
 now it's calculator time to figure the scale, just on 1/48th so "O" Gauge figures will be close enough.
The only other pic I've found is from the bridge to rear over the stern.
Damien
« Reply #45 on: May 18, 2008, 04:55:15 pm »
Put her back in the water again today after adding to the ballast and she behaves and looks a lot better.
Edward Pinniger
« Reply #46 on: May 18, 2008, 05:40:47 pm »
Looking very nice on the water! I hope to take some similar photos of my own boat soon, but it hasn't run since I finished it.
To Damien - the Workboat hull is about 56cm long, so your 15.3m prototype would scale out at 1/27. 1/24 figures would probably be OK for this.
Damien
« Reply #47 on: May 19, 2008, 03:47:51 am »
Thanks Edward, School was too long ago it seems & i got the calc's wrong.
D.
timg
« Reply #48 on: May 19, 2008, 08:46:33 pm »
hi all
if your looking for a seaport tug have a look on ebay Item number: 260241947209
no connection just a customer
great conversion dickyd
cheers spud
Page created in 0.342 seconds with 21 queries.
