Author Topic: Who sells keel bolts?  (Read 1492 times)
« on: January 29, 2008, 09:11:17 am »
Hi Chaps
I am looking for a supplier of keel bolts. I have seen them but cannot remember where.
Help please
TT
MikeK
  • Utter Bloody Chaos !!
Re: Who sells keel bolts?
« Reply #1 on: January 29, 2008, 09:19:16 am »
Hi TT - PJ Sails do a removable one out of C/F for the A Boats. Works a bit like a two part telescope - ie the wider bit is secured in hull and the narrower one (attached to keel) slides up until a tiny shoulder stops it at the hull bottom. Might be usable in other boats ??
regards
tobyker
« Reply #2 on: January 29, 2008, 01:40:04 pm »
I believe that proper model yachts as designed by Mr Hobbs used motorcycle or cycle spokes.
roycv
« Reply #3 on: January 29, 2008, 04:41:40 pm »
Hi tobyker can I also sign on as a fan of Mr. Hobbs?  I have some of his books.  Also I met his sister many years ago, she used to run a small engineering company in Herts.  She gave us some of his books that he used to review for a Model Engineer magazine and they are in our club library.
Regards to all Roy
Big Ada
« Reply #4 on: January 29, 2008, 04:54:50 pm »
Hi TT,
For fixing diferent weight keels to my Thames Barge I use 6mm studding (threaded rod) with a 6mm wingnut inside the hull.
Can't the Dingdan man help?.
                  Len    :)
« Reply #5 on: January 29, 2008, 05:32:51 pm »
Hi TT,
                  Len    :)
You write it down for me in Chinese and I will see what he do  {-) ;)
tobyker
« Reply #6 on: January 29, 2008, 10:50:30 pm »
roycv - I have a Hobbs designed yacht built by an uncle's father in 1922 - all proper bread and butter stitched together with wire. As I measured the sails they fell apart. In the shed "pending rebuild".
roycv
« Reply #7 on: April 01, 2008, 10:23:26 pm »
Hi tobyker, just got back to this thread!  Which Mr. Hobbs sailing boat have you got? I recently restored a couple of sailing boats from the 50's, on the first boat I sewed the sails.  On the second boat I used Hemmite ironed between the hems of the sails.  Once the templates of the sails are made it is very quick and appears to stand up to the wind and water.
regards Roy
tobyker
« Reply #8 on: April 01, 2008, 10:46:42 pm »
Not sure which boat, Roy. She was built 1922 by an uncle's father, 'cos he couldn't sleep very well after his experiences in the trenches. The deck is a single piece of pine, about 1/8" thick - can't get the stuff, nowadays.
