Author Topic: Advice on power...  (Read 2285 times)
Guy
Advice on power...
« on: February 07, 2008, 07:07:45 pm »
I have a small trent class life boat from model slipway, it is 500mm long and 180 wide. I have installed 2x M2 prop shafts with 30mm 3blade plastic props. They are run by 2 MFA torpedo 400 motors via an mtroniks viper 15 ESP and a 6 cell 2000mAh battery pack.
My problem is that the plastic props have broken, got damaged in the car and lost a blade or two on the water. Also she is slightly slower then I had hoped.
Can anyone point me in the direction of a supplier of brass props for M2 shafts?
Also i have now wired one motor the opposite way around so would therefore need one RH and one LH prop, is this correct for a twin screw boat?
Is there any way i can get more power out of this set up? The battery lasts a long time so more jucy motors could be an option but would i gain anything with out changing the battery?
Thanks for any advice, Guy
alan colson
  • I Just Dabble In Model Boats
Re: Advice on power...
« Reply #1 on: February 07, 2008, 08:40:37 pm »
I had a 3 bladed brass prop made to fit an unusual size shaft a few years back. This was done for me by a company called SHG.
Hope this helps
Alan
« Reply #2 on: February 07, 2008, 08:43:27 pm »
PropShop could supply off the shelf.
But dont know the situation since the takeover.
« Reply #3 on: February 07, 2008, 09:16:20 pm »
Try red bank models Wingertaz on the forum pm him
« Reply #4 on: February 07, 2008, 09:32:58 pm »
Hi Guy, my 400 motors run on 7.2v
I am also making the George Turner MTB which he reckons will run well on the Graupner speed 400 motor with a 7.2v 2000mAh battery and a 2 blade 25mm prop.
The MTB is more or less the same size as your lifeboat.,
Dont know if this helps. :-\
boatmadman
« Reply #5 on: February 07, 2008, 09:48:34 pm »
Try Gsitek props, they are good and give excellent service.
http://www.gsitek-props.co.uk/
Guy
« Reply #6 on: February 07, 2008, 11:37:02 pm »
Thanks for all your help, I wish I had asked yonks ago!!
Its reassuring to hear other peoples tales ad tips.
Guy
OMK
« Reply #7 on: February 08, 2008, 12:52:07 am »
How else do you think the rest of us got to be such smart asses?
Welcome aboard, amigo.
« Reply #8 on: February 08, 2008, 05:51:07 pm »
PMK never a truer word spoken in jest O0
Page created in 0.097 seconds with 21 queries.
