Author Topic: Huntsman motor  (Read 5761 times)
funtimefrankie
Huntsman motor
« on: February 13, 2008, 04:27:20 pm »
I have a Graupner speed 700 turbo in my GF 34 inch Huntsman, driving a 45mm 3 blade brass prop with 9.6 volts.
This motor is used because that's what came with it when I bought it part built.
Its seems heavy, although the boat is fairly nippy I feel it could do better.
Any Suggestions? please.
Frank
banjo
Re: Huntsman motor
« Reply #1 on: February 13, 2008, 05:41:32 pm »
 O0
I got the same set up 'cept the prop size..
Go down to a smaller prop....
You'll get more revs for you amp and it will go quicker!!
Promise..
 O0
PS
I got a graupner 2 blade black "fibreglass"  in mine which I gradually "modified" smaller & smaller.
Re: Huntsman motor
« Reply #2 on: February 13, 2008, 05:54:49 pm »
Frank ask Stavros because no matter what anyone else says to use he will insist the set up on his Huntsman is the best. O0 ;)
banjo
Re: Huntsman motor
« Reply #3 on: February 13, 2008, 06:07:19 pm »
Then I suggest a contest!!!!!!
(He said boldly throwing down his gauntlet)
 ;D
banjo
Re: Huntsman motor
« Reply #4 on: February 13, 2008, 06:15:52 pm »
I also have a Huntsman and run a MFA850 water cooled running a 55mm prop and a single 12vgell cell and yes it planes but not spectacularly,what you and I have to consider is it is a heavy boat designed fro a petrol engine that is it's problem
Gell cell!!
Its no contest....He is running a snow plough!!!!!!
 O0
Re: Huntsman motor
« Reply #5 on: February 13, 2008, 09:36:27 pm »
hang on DickyD if you had read what i had put on a previous Huntsman thread,you would have noticed your slight boo boo,I am also looking for an alternative set up
Re: Huntsman motor
« Reply #6 on: February 13, 2008, 10:09:16 pm »
Ooooops !!!!! :embarrassed:
funtimefrankie
Re: Huntsman motor
« Reply #7 on: February 13, 2008, 10:12:40 pm »
Re: Huntsman motor
« Reply #8 on: February 13, 2008, 10:19:35 pm »
I had one like that on my PT boat but I found it went faster with a finer pitched prop, also 2 blade. O0
Mind you that photo wasn't on here when I wrote this. It looks fine as is O0
Re: Huntsman motor
« Reply #9 on: February 13, 2008, 10:35:38 pm »
Well i would leave it well alone it seems that it fly's
banjo
Re: Huntsman motor
« Reply #10 on: February 13, 2008, 10:56:25 pm »
 ;D
 Go for a 2-bladed, of carbon fibre reinforced nylon. Propeller Ø 40mm
by Graupner
but certainly not from EBay
 O0
PS
...then.....go to a 12 volt pack!!!!...12 Volt 2200mA NiMh 2/3 Sub C Power Pack ( GP ) (Thanks ModelPower)
funtimefrankie
Re: Huntsman motor
« Reply #11 on: February 14, 2008, 08:49:27 am »
I'm going for the ebay prop, only the price of a pint , I'll put the Graupner one on the shopping list for next time I'm at a show or decent shop.
The 12 volt pack may have to wait as it would involve a new charger as well.
Frank
martno1fan
Re: Huntsman motor
« Reply #12 on: February 14, 2008, 03:48:51 pm »
why not try a brushless motor and lipo battery?, lighter more powerfull and longer runtimes  O0.
explorer750
Re: Huntsman motor
« Reply #13 on: February 14, 2008, 06:21:37 pm »
While not try running it on two 7.2v ni-mhs giving you 14v my deep v runs this and it flies.
funtimefrankie
Re: Huntsman motor
« Reply #14 on: February 14, 2008, 10:37:21 pm »
Limited budget
I'll have to check the max voltage the ESC allows
explorer750
Re: Huntsman motor
« Reply #15 on: February 15, 2008, 10:56:40 am »
What esc are you using? The electronize range can take that voltage easily.
grasshopper
    • A1 Hobbies Ltd.
Re: Huntsman motor
« Reply #16 on: February 15, 2008, 12:12:33 pm »
More to the point - where do you get a pint for £1.25?
have a look at these:
http://www.ripmax.com/11index.asp?category=050-010-080&selectedtab=050
Whenever I get to a particular model shop in Newark that imports Graupner stuff - and have money to spare, I buy loads of different props - they're not that expensive and you need to experiment rather than do calculations
funtimefrankie
Re: Huntsman motor
« Reply #17 on: February 15, 2008, 09:23:34 pm »
I was counting in the P&P = £2.20, price of a pint in "The Guest House"  Southport....nice O0 O0 O0
Jonty
Re: Huntsman motor
« Reply #18 on: February 16, 2008, 10:32:37 pm »
  £1.32 for a well-kept pint of Sam Smiths in the Halfway House in Queensbury, conveniently next door to my shop.
I eat my peas with honey,
I've done it all my life;
funtimefrankie
Re: Huntsman motor
« Reply #19 on: February 17, 2008, 04:12:48 pm »
Are well you learn something every day. My shaft is different thread to the eBay prop. :( Should have bought the pint.....
Also the current prop is 40mm :-\
red181
Re: Huntsman motor
« Reply #20 on: March 14, 2008, 11:18:47 pm »
My 42" Huntsman 28 has a graupner 700 bb turbo, 12 v,2 x 8.4 3300 nimh's, wired to double voltage, as the nominal voltage goes up to 19.2 volts. I originally ran a 12v 3300 nimh, going up in voltage was a massive improvement. Luckily I have a water cooled ripmax esc that can handle 19.2 v.
THe prop is like the ebay one, 35mm, "s" blade. I have tried "x" blade, as small as 30mm, as big as 50mm, both 3 and 2 blade, the 35mm and 40mm seem to be the best, the 35mm I think is just bordering on too small, as someone told me it was on the verge of cavitating. Its a heavy old boat, all ply, it flies on this combo, right up on the plane, but I only get 12 to 15 mins.
A second set up was graupner 9.6v speed race bb. Very amp hungry motor, but at 12v battery pack was almost as quick. I am no expert, but in the testing I have done, you have to push the voltage right up on these graupner motors, then they really come into their own. I'm off to Ellesmere show sat to get a battery pack made up, to 16 cells, 2x 8 packs to mount either side of the prop shaft, then I am at the max of the esc and motor! It will prob catch fire! ( then my aerokits Fireboat can come out!)
Hope that helps.
PS....I think Graupner are at tyhe Ellesmere show, perhaps if you can get there they can help?
Paul
Re: Huntsman motor
« Reply #21 on: March 14, 2008, 11:27:03 pm »
Before you go spending your money try Ian at Component shop he will do you a pack up at a very reasonable price,add in Traders section
andyn
Re: Huntsman motor
« Reply #22 on: May 22, 2008, 11:42:51 am »
Why don't you try stuffing a merco .61 in it, thats what I did  O0
grasshopper
    • A1 Hobbies Ltd.
Re: Huntsman motor
« Reply #23 on: May 22, 2008, 12:18:36 pm »
The way things are going, it's getting to the stage where Li-Po power is a reasonable cost alternative to Ni-Cd, NimH and in some cases Lead Acid.
Brushless motors are also dropping in price where they should be considered over brushed motors - especially when the power / weight ratio is an issue.
Getting boats like the Huntsman to perform for any decent length of time has always been an issue if doing it electrically - now finally, there is a viable alternative.
Mind you, for true scale enthusiasts - the ultimate should be two four stroke engines.......Oh that sound..
