Author Topic: Servos servos servos which powerfull ones? Please help  (Read 2776 times)
offshore1987
« on: February 18, 2008, 03:20:09 am »
Hi Chaps  O0
I need to put some powerfull servos in my tito neri and i have no idea what ones to get  :D Iv been lookin online at some, if you have tryed or can give any info would be great  ;D
Il start by saying i am the most useless person when it comes to numbers and rc elecs ever lol  :angel:
Well i have tryed some 3003 servos in my tug but they couldnt deal with the power
The ones iv seen are:
Hitec 645MG BB size 41/20/38 ( 9.6KG at 6v ) £29
Thunder tiger super torgue digtial car servo size 41.8/20.6/39.6 ( 14.5KG at 6v ) £56
Hitec HS5995TG size 40/20/37 ( 24KG at 6v ) £75
Hitec HS5955TG Titanium digital gear servo size 40/20/37 (24KG at 6v ) £75
Iv never used a Ditial servo before so not sure what they are all about??
My radio gear in the tito is a... Futaba T6EXAP Computerized Airplane System on 40Mhz << if that helps with anything. I was thinkin of gettin a 2.4 set up at some point later on too so i guess i should take into acount what servos will work with that set up too :)
Any help would be soooo good :)
All the best
banjo
Re: Servos servos servos which powerfull ones? Please help
« Reply #1 on: February 18, 2008, 04:19:34 am »
 8)
Read the thread on RC Forum Tito Build.  You know where it is.  All the detail is in there.   It has been discussed numerous times.
offshore1987
« Reply #2 on: February 18, 2008, 05:27:39 am »
Ta i did do before postin about servos, nothing on there is very powerfull though  O0
All the best
FullLeatherJacket
« Reply #3 on: February 18, 2008, 08:53:08 am »
Offshore
Don't worry. All the servos you have mentioned should work with your radio. They are - or ought to be - compatible with any current RC gear; the difference is in the way the servo deals with the signal pulses; not the pulses themselves. One point you should be aware of is that digital servos take more current than "normal" types, so you'll need a bigger RX pack (unless you use a BEC or a P92 DB).
FLJ
dms toucan
« Reply #4 on: February 18, 2008, 10:45:15 am »
I have been using cirrus cds750/mg 11kg digital servos cost £16 on my
ASD tug no trouble so far.
Martin
catengineman
« Reply #5 on: February 18, 2008, 10:52:00 am »
Talk to Westborne Models they supplied me with two servos that overcame the prop power
They were "blue something" Ill look back and see if I can find out the correct name
R,
Page created in 0.029 seconds with 19 queries.
