September 16, 2026, 04:54:51 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Technical, Techniques, Hints, and Tips
Radio Equipment
digifleet tx
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: digifleet tx (Read 3434 times)
nightowl2912
Guest
digifleet tx
on:
March 15, 2008, 07:30:23 pm »
Hi all, iv got an old digifleet xp/fm. iv lost the charger for it,
dose any one know the pinout for the 5 pindim on the bottom of the TX
so i can make somethink up
thank you for any help
barriew
Full Mayhemer
Offline
Thaxted, Essex
Re: digifleet tx
Reply #1 on:
March 16, 2008, 04:46:44 pm »
Looking at the pin end of the plug, three pins at the top, the Left is Positive, Top is Negative, Right is unused.
Hope this is clear.
Barrie
nightowl2912
Guest
Re: digifleet tx
Reply #2 on:
March 17, 2008, 06:15:12 pm »
Thank you for that, mine looks different to yours,
looking at my socket looking left - right pin 1 used, pin 2 unused, pin 3 used, pin 4 unused, pin 5 used
barriew
Full Mayhemer
Offline
Thaxted, Essex
Re: digifleet tx
Reply #3 on:
March 18, 2008, 08:07:38 am »
The plug definitely only has three pins - didn't look at the socket :)
I can try to see if I can see the back of the socket if you wish. It is the same model.
Barrie
FullLeatherJacket
Guest
Re: digifleet tx
Reply #4 on:
March 18, 2008, 08:43:33 am »
Make sure there's some juice in the battery by watching the meter when you switch on. A flicker = life. Switch the Tx OFF. Grab a digital multimeter; set it onto the 20v DC scale and shove the probes into various combinations of holes. It will show one of three things; nothing, -v or +v. It's the latter you want. You now have identified Red = +ve and Black = -ve for a new charger plug.
If 'twere mine, I'd disconnect the DIN socket and fit a standard 2.1mm DC power socket, to fit any number of plug-top chargers. Saves mucking about later with a DIN plug.
Works for me. Suit yourself.
FLJ
barriew
Full Mayhemer
Offline
Thaxted, Essex
Re: digifleet tx
Reply #5 on:
March 18, 2008, 08:51:12 am »
FLJ is right - a multi-meter is the way to find out for sure, BUT I've just checked the outside of the case and the socket is a 5 pin. Don't have time now to take the cover off, but my guess is that you ignore the two outside pins. Should be able to work it out from that.
Barrie
nightowl2912
Guest
Re: digifleet tx
Reply #6 on:
March 19, 2008, 06:09:41 pm »
Thank u for all the help, i removed the cover and the socket is mounted on a pcb,
so i used a multimeter and got it sorted
thank u again
Print
Pages: [
1
Go Up
« previous
next »
Radio Equipment
digifleet tx
