I have Bluebird to thank for his masterclass on the Cervia build for the next stage.
I fitted a 2mm plywood deck, using Z-Poxy 30 minute adhesive. This was installed as normal inside and "level" with the top of the shell of the hull. Weighed down with batteries etc it was left to cure overnight. I then smoothed off any protruding deck edges.
I had some plastic safety notices, redundant from a closing warehouse, 2mm X 45mm X 33mm. Using two of these I have fixed them, using the same adhesive, over the plywood. This time smoothing any protruding side edges. Together this has formed a fine, firm deck.
I will follow the same build line as the masterclass to fit the bulwarks then cut out the various deck openings.
The result in pics below.
