OK, so now I have your attention.........
How do you wire a boat up? This is not a stupid question - but one I seriously want an answer to! I know what it needs - I just don't know how to wire it up so here goes.
Model is a single screw HFM ORSV. Prop is 38mm but I need as follows: suitabloe length shaft plus what type of coupling and what sort of motor to make it plug along at a scale speed?
Hiow do you: Connect up a servo, what is it connected to, where does the ESC it in all of this? Where does the RX fit in and how? Basically, a wiring diagram from TX to [prop would be good, with ideas on kit needed. Good servo, ESC, Rx, battery - I have a Futaba 2 ch TX - what do I need to do to make it work with this kit....is FM better than AM? What is the best battery for the boat so it runs for ages?
Spare a thought about us types who work like billy-O making a moel look presentable and then stick it on astand somewhere.....because we ain't as clever as you guys!
Jonty
