Well,
Got some more work done today - built new motor mounts to correct the drive angle - the motor shafts are now in line with the prop shafts. The hull and deck got a liberal coating of grey automotive primer - needs rubbing down now and recoating with a couple more coats of primer, then I can get on with the colours for the hull bottom and the deck, and then laquer it all in.
Does anyone have any pictures or similar of the wateling for the BB ? My plans do not show it. Also - does the red paint on the hull bottom come up to the waterline or should it be below ?
The superstructure has had a load of balsa set between the ribs which form the sides of the main cabin area and bridge and the rear section has been started. Still need to do the doorways at the front of the main cabin sides and the outer skin needs adding. This bit I am waiting for as the model shop have not had any in stock.... should be here tomorrow hopefully !
Also - took it down to the pond for a run - goes really well, quite pleased ! :) Lifts the outside prop when turning full rudder at full speed, but, it turns
*really* tight ! If i flick the rudder over quick enough it will 'flick' its back end around like one of those jetboats they race in the swamps !
I May shift the link arm from the servo to reduce the rudder throw a little. I hear that 30 degrees is optimum, I haven't measured properly, but, as a guess, I would say I am probably nearer to 40 degrees with its current setting.
Seems to get up onto the plane quite easily - at least, I think it is planing - it seems to lift the front half of the hull clean out of the water and scoots along nicely.
And then it happened :
I sunk it already !
I clipped the bank at the pond at speed and it just tipped it over onto its side
- luckily it was within arms length and I was there quickly enough to catch it before it went completely under
So, it is now sitting on the workbench slowly drying out before I can do any more work to it !
Will post some more pics soon !
Andi
