Fascinated by steam since quite some time I decided it was time for some real experience instead of reading about the subject. I must say actually building such an engine makes you understand things a lot better. The exchange rate of the US$ made buying an engine an easier decission. I have no metal-working experience, no lathe or drillpress so I chose the PM Research '#8 Marine Steam Engine'.
It arrived, well packaged, with a simple but clear manual. As I said no fancy machinery needed, a screwdriver, small file en a small pare of pliers suffice.
Casting and materials are of good quality, no mentionable flush, everything ready to assemble
The main block comes ready assembled.
One servo only can control speed ahead and reverse and full stop.
Crank and shaft are installed.
Bottom of one of the cylinders is installed, on the right there's the top. Cylinders are made from anodised alluminum, apparantly solid and very wear-resistant, it seems to be used a lot in aviation.
The piston is beeing fitted in the cylinder. Perfect fit!
This is how the cylinders are mounted on the main block. Before they're closed there are some adjustments to be made.
The pistons must stay 2 mm under the top of the cylinder when in their highest position..
Nice cover for each cylinder.
I've run this engine shortly on compressed air and I was surprised by the power and response. However I don't dare to run it anymore untill I have the right kind of oil. Is steam oil necesary? Advice anyone?
When I can run it on the right oil, I'll post a small film here.
All in all I'm very pleased with this engine. Hopefully I can install it in a nice boat in the near future with a suitable boiler (maybe this one:
http://www.maccsteam.com/Horizontal_Marine_boilers/3_and_half_inch/3_and_half_inch.html ?).
Cheers, A!H.
