Pages: 1 2 [3]   Go Down
Author Topic: building a Topaz steam launch  (Read 27991 times)
Meyer
Re: building a Topaz steam launch
« Reply #50 on: June 13, 2011, 10:06:36 pm »
Hi thanks for all your posts, and interest shown,
I was quite aware of the weather conditions, and realized that I just had a small window of opportunity to sail her, I was not to far out, and not too deep there,!!! I waited 4 hours for the weather to improve enough to sail her, so I think I had all the bases covered. There's always conjecture over how to set the balance of a launch, ans I think this was'nt bad for the first time out, I will now trim her out for next outing, " on a mill pond", !!!!
getting  back to VHT spray paint " how do you, post cure? I'll give it a go,
Underpressure
« Reply #51 on: June 13, 2011, 10:31:57 pm »
Hey, it's your boat Roy, you sail it wherever you like  :-))
My first experience sailing a steam boat was on Cheddar reservoir (long before the factory had the model lake), sailing the Cheddar Models factory demo Amaryllis open launch in a howling gale with John Woodroofe trying to do the salesman bit on me. The fact I could not hear a word he was saying due to the severity of the wind was no nevermind to John (as those who knew him would know).
It was brilliant fun and shortly after that I bought my first Puffin engine kit.
mogogear
« Reply #52 on: June 14, 2011, 01:59:08 pm »
A fine job Roy..... Perfect conditions to sail are far and few between here also --You just need to see them run after all the work..
Congratulations on a splendid boat that will put you in a many a fun conversations with passers by!! :-))
Meyer
« Reply #53 on: July 02, 2011, 05:58:07 pm »
Hi, many thanks for all your posts, most appreciated, I have fitted the sero to the whistle, and have found a great UK Co, to stove enamel my chimney, willl post details when I get it back,plus more complete pics and pics on the water,
many thanks again, Roy
Meyer
« Reply #54 on: July 05, 2011, 11:16:29 am »
Hi All,
My Topaz is now finished, !!!!, just need to trial her again at the weekend, weather permitting,
got my chimney stove enamelled by www.crimblepowdercoating.co.uk tel: 01484-843175 it cost £15 great service,
Meyer
« Reply #55 on: July 07, 2011, 03:51:53 pm »
Hi Roy congratulations on a beautiful job,but I have a question as to why the engine needs 60psi to perform satisfactory? as most of these small engines that I know of including my own run very well on 20 - 40 psi this is in no way a criticism
Hi, Well the engine, has never been run in , !!!only ran once by the owner in 1989 , and these engines by Hemmens need loads of running in, I run on comp air for ages, and only now its starting to respond to run at lower PS1, I've got her down to 40 psi now, !!! but I have watch the pressure that can build up because of the small boiler, , but I'm pleased with her, and it getting better ever time I run the engine.with try 2nd trial at the Dam at the W/E. Cheers for your interest,
Meyer
« Reply #56 on: July 07, 2011, 08:21:16 pm »
Here's an other view, of my completed Topaz, many thanks for the interest shown in this project,, , I think this now complete, so now on with my next project. thanks again
« Reply #57 on: July 07, 2011, 11:37:43 pm »
Hullo Roy......one point I missed until today ..... :o is question of the overboard discharge tube nipple?????? on the STDB side & just FWD of the gas tank discharge valve
When I look closer...it was evident as early as the image from June 13.........
I cannot see any internal connection images.......is it for blowing down the boiler?   :-)
Meyer
« Reply #58 on: July 08, 2011, 09:33:04 pm »
Yes Derek, that right, , here's a " on the water pic, on a sunny day, weather with less wind, !!!!
Meyer
« Reply #59 on: July 15, 2011, 09:43:22 pm »
Here's my Topaz I have drilled a 2mm  hole for the prop pin to secure prop, !!!
Meyer
« Reply #60 on: July 16, 2011, 12:06:51 pm »
is that the Standard Prop shop prop that comes with it ? do you ball race both ends ? by the way is that the Topaz that was on ebay ?
HS93 (RIP)
  • I cannot spell , tough
« Reply #61 on: July 16, 2011, 10:20:28 pm »
is there a reason for this post ?or did you just forget to answer it ?
Peter
Meyer
« Reply #62 on: July 16, 2011, 10:46:50 pm »
Hi Peter, sorry forgot to add post, Yes its the std prop and prop shaft, , how ever I'm not keen on it, I like to fit the Prop Shop ball raced propshaft, best,. Thanks for your post.
Meyer
« Reply #63 on: July 29, 2011, 12:08:29 pm »
Hi Peter,
Getting back to the prop it is a prop shop STM/2230/4blade/left curved/ threaded M4,
I retimed my engine the Caton and have speed biase  in the op direction, so changing the prop to a right curve, hope this info is of help to you
Pages: 1 2 [3]   Go Up
Page created in 0.018 seconds with 18 queries.
