Hi Stuw and Jim
You're both very kind, I think we all spur each other on to keep standards up..!
I've now got all the electronic side of the build together and been able test as a fully integrated system rather than individual parts.
In no particular order:
The boat is getting a heading hold gyro (I had a spare), this is going to be enabled when the skier is enabled to keep the hull heading in right direction.
I've made up some Rx controlled switches, so on/off from a Tx toggle switch.  They have an integrated voltage regulator, so input voltage can be 4.5v to 28v and output can be from 0.8v to 20v, variable for whatever devices are being powered.  So they're pulling power from the balance port of the lipo rather than the Rx. (And can supply more current at a range of voltages. Voltage Regulator is an MP1584en, RC switch is a Pololu 2803.)
A couple of plastic 'stand offs' hot glued in to allow fixing.  3 outputs per switch, so up to three devices can be enabled from same channel, fine for current needs with some expansion built in.
And for some engine sounds...
This is a DIY Arduino based system (not my own design but my version of it) with a dual channel amplifier and one of the voltage regulator boards that uses actual Aquarama V8 startup and running sound samples, running two speaker channels, one speaker built into the bow, and an Audio Exciter that going to be attached under the forward deck, it uses the deck as the speaker surface...  Engine cranking startup sound then a proportional engine speed.  Sound on or off via a switch on the Tx.
And here's the Audio Exciter:
Weighs in at 19g... 3w output.
Three 'boxes' being built in for the electronics.  One aluminium case for the ESCs to act as a heatsink, two plastic cases to port and starboard for the rest.
Next task will be to fit the devices into the cases.
As a side note, I've been really pleased with the Arduino (I'm using the really small Pro Mini), and started to wonder about using one to sense for the presence of water in the bilge and use telemetry to push a warning to the Tx... Anyone tried that..?
And if you've got this far, here's a 10 min video showing the light and sound build so far and the tweaked motor controls too.
https://youtu.be/Rj3ynymx54YBeen good to get this lot together.
Best regards
David.
