Pages: 1 [2] 3 4 5   Go Down
Author Topic: Beginners Story ( a pilot boat )  (Read 30620 times)
Mike0001
Re: Beginners Story ( a pilot boat )
« Reply #25 on: December 10, 2014, 09:59:00 pm »
thanks
a bit rough round the edges but bit more shaping and with primer and paint it should look ok
really enjoyed it so far and for me that's whats its about
plug
« Reply #26 on: December 10, 2014, 10:22:59 pm »
What clearcoat did you use, is it the acrlic, waterproof when it dries, i've no idea what to paint on ply and what clearcoat to use to waterproof
regards Jack
« Reply #27 on: December 10, 2014, 10:31:12 pm »
plug if you want to waterproof fly go to Halfords and get some of their car laquer it is waterpoof
Mike0001
« Reply #28 on: December 10, 2014, 10:38:47 pm »
is all laquer waterproof ?
what about this one ,
http://www.wilko.com/metal-and-specialist-paint/wilko-quick-dry-gloss-paint-multi-surface-aerosol-clear-400ml/invt/0218908
it says interior and exterior....... bit cheaper ?
« Reply #29 on: December 10, 2014, 10:46:33 pm »
All Laquer is waterproof BUT BUT BUT ....A word of WARNING here NEVER NEVER mix and match different makes of paint a Big NO NO as it will end in TEARS.
The Halfords paints are Acrylics great you can use ANY of their products.
The link you have just put up is an ENAMEL paint.....put an Acrylic over that one and hey presto INSTANT reaction and I will say then told you so  O0 O0 O0
Mike0001
« Reply #30 on: December 10, 2014, 11:03:32 pm »
gotcha...... stick to same brand names
this is my first model and big learning curve
for jack , this is my first boat so listen to Stavros
this thread is to document problems I come up against and solving issues..... so far guys have came up trumps..... do you have a build log for your boat jack ( plug ) fun way to not only document but for others to watch and beginners like myself to pick up tips
plug
« Reply #31 on: December 11, 2014, 11:46:09 am »
Stavros (Dave) thanks for the info, did'nt know Halfords paint was all acrylic.
Mike, no not doing a build log, not started it yet  i'm a slow worker, two weeks thinking to produce an hours work
regards Jack.
« Reply #32 on: December 12, 2014, 01:54:05 am »
Reference the "all around bumper" - I used a broken fanbelt (from SWMBO's tumble dryer), glued on with epoxy resin.
See my build here: http://www.modelboatmayhem.co.uk/forum/index.php/topic,47660.0.html
Mike0001
« Reply #33 on: December 18, 2014, 04:38:37 pm »
so managed to get a bit more done
shaped the hull and filled in tiny gaps and general making the shape a bit more rounded and smooth
also added the comin ? not sure if correct word 4 strips of wood around opening in hull.
this is when I found out about section I should have cut, for the cabin you have to cut corners of the middle frame of cabin for it to slide over hull.
primed just the cabin for now ......... starting to think about electrics next     :-))
filled in round top of boat
some pics of my trials
superglued then filled round edges
used this filler from wilkos only 2 pound per tube for wood and easily sandable
roughly filled when set round the edge
cabin now primed
lightly at first
two more coats
Mad Scientist
« Reply #34 on: December 18, 2014, 09:39:24 pm »
Looking good! :-))
I, too, have been thinking about the electrics. My boat will have a 385, which is what the designer recommended for use on small ponds. I just might buy 6 different props in the hope that one of them will be 'perfect' for this boat.
Tom
Mike0001
« Reply #35 on: December 28, 2014, 07:15:55 pm »
28/12
so a bit of painting and lacquering later I am getting towards electrics but I have a few questions
parts left, recognise some "extras " stand strengthners optional I decided not to use
so in order does anyone have a pic of completed "antenna" ie how to put together top left in pic
next door optional ?
other items no idea, I have bought an aluminium mount and do not know what other parts are for
help needed ... thanks
more pics to follow
Mike0001
« Reply #36 on: December 28, 2014, 07:21:10 pm »
decided on silver deck orange cabin, black bottom and orange sides
looks pretty good in my opinion and will be able to see on water
overall not bad for first effort
paul johnston
« Reply #37 on: December 28, 2014, 07:33:22 pm »
Your front windows appear to be the wrong way round, they should follow the roof line.
Mike0001
« Reply #38 on: December 28, 2014, 07:45:58 pm »
hi
had a few say that, will alter once I can find out best way to cut it out and reglue with out to much damage
Mad Scientist
« Reply #39 on: December 28, 2014, 09:10:23 pm »
Mike,
Here's my interpretation of the bits & pieces in your photo:
Antenna: From the top -
Two mast yardarms
Two bases for masts
Two masts
I'm assuming those little bits are the bottoms, backs and ends for the running light boxes
Motor mount: How you mount the motor depends upon the motor's shape. Use the supplied mount or create your own.
Door: You could attach it in opened or closed position. You could install working hinges and a latch, too. If the door is open, you could instal a master on/off switch just inside.
The items in (C) are rudder mechanism mounts, according to my set of plans.
And (D): The shorter arches and straight pieces are formers for the wheelhouse roof. The other pieces are spacers for the coaming, I think.
That's just my interpretation, of course. The designer probably had something entirely different in mind!
Tom
Big Ada
« Reply #40 on: December 29, 2014, 05:53:25 pm »
This was made from a free plan in a magazine, all scratch built in Styrene sheet.
Len.
Mike0001
« Reply #41 on: January 02, 2015, 07:39:50 pm »
need some help/info
inside of boat do I waterproof and what to use
all I have is plasterers webbing tape, the tape you use to join the plasterboards and pva glue ?
also no details about were to drill for rudder and propshaft anyone care to share details
thanks
« Reply #42 on: January 02, 2015, 08:47:33 pm »
ERM I do sinceerely hope you have acces to the rear of the deck what I mean is hope there is NO bulkhead to stop you getting access to the rear if so a hole will have to be cut to gain access.....It is such a shame you didnt ask for this advise when you were building the hull up as it would have saved you a lot of greif.
You will need to drill a hole for the rudder I would hazard a GUESS 40 mm from the stern and a hole for hte shaft around 50 mm fwd of this....PLEASE PLEASE get s shaft and a motor mount BEFORE you start drilling holes and also a propellor
« Reply #43 on: January 02, 2015, 08:48:59 pm »
As for waterproofing this is simple ...get some fibergall resin mix some up and simply pour it insdie and then slosh it around till you cover the whole inside of the boat pour the excess out of it
Mike0001
« Reply #44 on: January 03, 2015, 11:50:29 am »
hi
well there is a rear bulkhead but access is really good I can get my little hands all the way in and feel around the rear of the boat, not quite sure what your getting at but all seems good for access ?
will put a pic up soon to show access,  also have to prop , motor shaft etc, will put some details up soon as well
Mike0001
« Reply #45 on: January 03, 2015, 12:24:04 pm »
so what running gear is going in
well what went into traplet boat on their stand was
mfa 719re540/1 motor
10 inch shaft
standard servo
from what I can gahter pretty standard rudder
marine vier 15 esd with built in fail safe
now I need to mount and position this
a few pics to show access for Stavros ( hope I have not messed up here ) and the running gear
to show good access ( I hope )
running gear to be fitted
« Reply #46 on: January 03, 2015, 08:32:01 pm »
it is going to be VERY tight,but you need to drill and fit the rudder in the rear compartment roughly half way between bulkhead and the stern.....as for the propshaft this could be fun as it is now guesswork to where a hole will be drilled .....I would hazard a GUESS that it will be APPROX and I say APPROX 100mm in front of the bulkhead you wont be far wrong with that then you can get a good angle for the propshaft to motor,I can see NO coupling in the pic to connect the shaft to the motor....you will need one !!!!...you need to get the motor to shaft in the same plane..............
Mike0001
« Reply #47 on: January 03, 2015, 08:52:51 pm »
thanks
so to recap hole for rudder through the keel half way from stern to rear bulkhead
for prop tube 100mm away from rear bulkhead, what angle roughly for this 45 degrees ? and also through the keel .
I also have the coupling it was hiding behind motor
Mike0001
« Reply #48 on: January 17, 2015, 02:31:16 pm »
need some help with regards to rudder mounts ? labelled c in picture
3 parts of wood ... how and where to mount ?
Big Ada
« Reply #49 on: January 17, 2015, 04:46:53 pm »
Have you bought a back dated copy of the Mag with the free plan in it, ALL the instructions are in it.
Rudder box.. Glue the bit with hole in it to the tops of the other two then glue it to the hull bottom behind the rear bulkhead with the hole near to the pointy end.
 I am remembering these details so I may be wrong.
Regards.
Len.
Pages: 1 [2] 3 4 5   Go Up
Page created in 0.11 seconds with 21 queries.
