Author Topic: MMM Portgarth build  (Read 454583 times)
T33cno
Re: MMM Portgarth build
« Reply #675 on: September 23, 2017, 03:55:13 pm »
Windows. No good just looking at em! time to do it.
So I drilled out a fair bit of material with my step drill before turning to the Dremmel
They'll be finished off with a round file when I make the frames
I've removed more matter from the top shelf frame to improve visibility
Unfortunately my cheap copy dremmel drum sanding mandrels are tom tit. So no more until I get some genuine ones  :((
I've also soldered 4mm brass washers to the front mast legs. So no more levelling up.
Made the front below deck access hatch (artistic licence  {-) )
I'm going to York MBC open day tomorrow  :-))
bfgstew
  • Comfortably Numb
« Reply #676 on: September 23, 2017, 04:26:09 pm »
Coming along nicely Andy, i do admire your work it is first class.
Stewart
"Give me a ping Vasili. One ping only, please"
T33cno
« Reply #677 on: September 23, 2017, 04:27:28 pm »
Stewart
Thanks Stewart, not bad for a beginner  :-)
Forgot. Rear fender fitted.
T33cno
« Reply #678 on: September 23, 2017, 05:33:28 pm »
Two coats of primer here over sanding sealer. Final coats will definitely look like steel  :-))
tugnut
« Reply #679 on: September 23, 2017, 06:14:00 pm »
Really taking shape Andy looking good  O0 .
T33cno
« Reply #680 on: September 23, 2017, 06:18:27 pm »
Thanks John  :-))
I was just typing this as you posted. I just had a look back at page one of the thread. Little did I know what I was in for {-)
So I started in March and progress has been a rollercoaster and I've come to understand that this is normal for the average builder.
Sometimes we get loads done and put many hurdles behind us and then we hit the doldrums of life getting in the way or a technical obstacle requiring help.
This last three weeks has been great and I think I finally have a grip on practical completion this year but with many additions or tweaks to keep me going next year.
I'm not sure yet that I'll light her up as I still live with the fact she can never be perfect so I'm drawn to starting the Maltby next and giving it all 8)
« Reply #681 on: September 23, 2017, 06:23:47 pm »
Some times problems, sometimes money, sometimes enthusiasm, sometimes a stupid mistake, they all add time to a project  O0 The window cutouts look very straight, I salute your accuracy. Regards the hatch, working vessels as well as military ones get changed and altered all the time, so a little artistic lisence isn't an evil.
T33cno
« Reply #682 on: September 23, 2017, 06:24:42 pm »
 :-)) O0 Yes I made mistakes a plenty. When the enthusiasm is working there's just no stopping.
Re straight lines. I was on my knees with dremmel flexi drive and dust mask on.
I made the mistake of putting the wheel house roof on the wrong way around and I didn't notice until I came to put the mast on. A good job I wasn't gluing it on  %%  as it fits perfect either way  {-)
T33cno
« Reply #683 on: September 26, 2017, 10:26:19 pm »
An hour per evening is my limit on work days now  :((
First brass window frame fitted.
The funnels didn't have enough height or taper at the base by the time I'd got them ground off so they were perpendicular.
So I've built them up with ply, shaped as necessary and resin coated before final sanding. The MMM supplied castings are tapered on four sides but the Portgarth is only tapered on two of those.
T33cno
« Reply #684 on: September 27, 2017, 10:09:49 pm »
Dremel sanding drums arrived so all the windows opened up for final finishing with files
Two down 27 to go  %%
Tomorrow is the Friday of my week. We call it fake Friday  {-) at our place
So I have All the real Friday on my own to build  :-))
Thornej
  • Newbie (for now!)
  • Model Boat Mayhem is Awesome!
« Reply #685 on: September 28, 2017, 02:08:34 pm »
Hi Andy,
Greetings from downunder.
What fantastic work you are doing! It's great to see. Thank you for sharing.
Now not sure I'll take mine out of the shed!  :}
Jeff
Thornej
  • Newbie (for now!)
« Reply #686 on: September 28, 2017, 02:24:33 pm »
Andy,
What size is your lettering?
Jeff
T33cno
T33cno
« Reply #688 on: September 28, 2017, 09:33:31 pm »
Everywhere seems short if 1/8 brass strip  :((
I’ve 20 on order with SMC back order  :((
Only got 12” left so going to be stalled on windows
May have to start bulwark ribs over the weekend
T33cno
« Reply #689 on: September 29, 2017, 08:19:28 pm »
Photos of todays effort.
All deckhouse windows done and masking up so I could spray sanding sealer on the rest of the sides and still be able to glue doors in place later.
Battery box knocked up
Forward deck hatch nearly complete
« Reply #690 on: September 29, 2017, 10:17:18 pm »
The concept of using brass strip over plasticard is a great idea :-))....and produces an extremely tidy frame result
However just at a rough guess  %) ...you have about 72 window corner bends to produce
Considering they all have the same corner radius, this would nearly warrant producing a small jig...with one fixed circular ring and one circular ring at an adjustable distance away ;D
T33cno
« Reply #691 on: September 30, 2017, 06:59:24 am »
The radii of the smaller windows (wheelhouse roof) is smaller when I’ve finished them with a file and is equal to a pair of 6” pliers in my right hand and brass strip in my left  {-)
T33cno
« Reply #692 on: September 30, 2017, 12:20:14 pm »
No need to drop onto ribs after all. Plenty to do on superstructure! I'm having a door day  O0
Mark up and drill
Make and fit hinges
Sanding sealer
Rub down
Sanding sealer
Rub down
Primer
Fit dogs and porthole
Primer
Leave till tomorrow
Top coat Rover Arum White
T33cno
« Reply #693 on: September 30, 2017, 02:19:35 pm »
T33cno
« Reply #694 on: September 30, 2017, 05:18:27 pm »
Great progress today or so it feels
Just some very minor filling for perfection once the primer is hard.
Masking tape over all attachment points and I’m going to attach the forward deck hatch to the deckhouse so it lifts off together
T33cno
Re: MMM Portgarth build......... brass tube cutting
« Reply #695 on: September 30, 2017, 08:21:58 pm »
I've been using brass tube for the hinges and to make sure they are all the same pin length I made the jig.
I picked up this tip on you tube to cut tube without crushing.
Just score heavily with a blade while rotating the brass then it will snap off clean with pliers placed near the score.
newdabbler
« Reply #696 on: September 30, 2017, 08:43:49 pm »
Terrific work Andy. Thank you once again for sharing your build with us. As a beginner with many questions, I am finding it so helpful and inspiring.
Graham
T33cno
« Reply #697 on: September 30, 2017, 08:47:45 pm »
Graham
I only started this year Graham so very much a novice myself but I have worked with my hands all my life and served an engineering industry apprenticeship which stood me in good stead.
Unfortunately I've had to work many things out for myself here but the info I have received has been invaluable.
The more you do the easier it gets
Feel free to ask questions in the thread, if I can't help someone else might
T33cno
« Reply #698 on: September 30, 2017, 10:53:10 pm »
Getting a bit more adventurous I’ve started the RIB frame.
This is one of two main legs that everything emanates from.
A little oversized but won’t be noticeable with the smaller metals off it later the idea is that I’m aralditing two stub sleeves into the deck so the whole frame can be easily fitted and removed.
T33cno
« Reply #699 on: October 01, 2017, 02:34:43 pm »
It’s times like this that I wish I’d d used araldite rapid  {-)
Pages: 1 ... 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 ... 52   Go Up
Page created in 0.732 seconds with 17 queries.
