Author Topic: MMM Portgarth build  (Read 450754 times)
T33cno
Re: MMM Portgarth build
« Reply #925 on: December 14, 2017, 09:40:14 pm »
SEE FOOTNOTE
SORRY BUT THE FORUM IS BROKEN AND IT TOOK HALF AN HOUR OF FAFFING JUST TO POST ONE PICTURE  :((
« Reply #926 on: December 14, 2017, 11:34:57 pm »
If there is to be no glazing, is there a risk of water retention and possible damage from prolonged immersion of joins and corners etc if not removed fully Andy?
I ask because you are obviously putting double the effort into this build than perhaps should have been required, and I would hate for your extra efforts to have a shorter lifespan than they deserve.
tugnut
« Reply #927 on: December 15, 2017, 08:04:21 am »
I would defiantly have windows, if the boat  is out and starts to rain, or someone gets carried away with water cannons its going to get wet in there.
I have never used glue, to stick windows i use Stix 2 3mm double sided tape  good stuff no messy windows :-))  ballastanksian said it all why spoil all that great work you are doing.
regards John B.
T33cno
« Reply #928 on: December 15, 2017, 08:41:12 am »
Thank you both
I’m not ruling it out but for now things are clearer in my mind without including that.
The inside of the wheelhouse will be no more vulnerable than the deckhouse or deck, it will all be painted.
I won’t be doing rain  {-) I’ll stay home and build something :-))
Thanks for the double sided tape tip John
The thought of making 24 windows is too much to contemplate just now  {:-{
« Reply #929 on: December 15, 2017, 09:00:56 am »
Andy......I am not sure what your issue is, but I have taken on one lost sole....missyd from Switzlerland and posted her hull images in her thread here tonight [Switzerland to Australia...then back to a UK server  O0]
What you need is another MBM member to pick up the ball & run with it to help you until this posting glitch is resolved......is there not a local who can help?
T33cno
« Reply #930 on: December 15, 2017, 09:01:27 am »
T33cno
« Reply #931 on: December 15, 2017, 09:04:25 am »
There isn’t anything wrong with my picture posting Derek
It’s just the same as ever except since the maintenance work it times out and reports a data base error please try again later.
I’m only inserting images hosted by myself I have never attached pictures
T33cno
« Reply #932 on: December 15, 2017, 04:01:12 pm »
I had to modify some parts to create enough circulation room
« Reply #933 on: December 15, 2017, 08:38:40 pm »
Looks lovely Andy.
I thought (when I saw the first picture) that it was a piano.      {-)
ken
Fastfaz
« Reply #934 on: December 15, 2017, 09:40:34 pm »
Will we see her in the water at Balne 2018?
    I would like to get a photo alongside my Pegasus (chopped Maltby hull).
            Can't wait for next year's towing.
               Cheers, Pete
T33cno
« Reply #935 on: December 15, 2017, 10:09:40 pm »
Two pianos now Ken  :-))  but I'm fed up trying with pictures until the forum is fixed  :((
Yes Pete most likely at Balne again, I like to get her 'bottom' filthy  {-)  saves weathering  :-)
T33cno
« Reply #936 on: December 16, 2017, 06:07:56 pm »
Testing..........Edit two attempts and nearly 5 mins just to insert one picture :((
EDIT
try another pic?
T33cno
« Reply #937 on: December 16, 2017, 06:13:27 pm »
still broken  >:-o
T33cno
T33cno
« Reply #939 on: December 17, 2017, 05:37:18 pm »
So time to celebrate 🎉 the forum is fixed and I got a new device so expect better pictures 👌🏆
Also notice that emoticons are posted from my phone! is that a new one?
T33cno
« Reply #940 on: December 17, 2017, 08:31:08 pm »
This is my almost complete masters chair prior to paint. I just have to make some armrests from styrene that will simply glue to the backrest. I've used FUSION to attach the seat base and back to the brass.
T33cno
« Reply #941 on: December 17, 2017, 08:36:46 pm »
Where the clock and barometer are is I believe the cable way for the kit on the mast etc. It will serve the same purpose if I do illuminate it.
Leeds model shop has started selling wood by Amarti? or Amati??
Anyway it is beautiful walnut and really cheap. The duck board is made from it and needs no further treatment
hama
« Reply #942 on: December 17, 2017, 09:46:09 pm »
Everything looks superb! You'e very talented and it's a joy to follow this build.
Hama
Tafelspitz
  • Model Boat Bedlam
« Reply #943 on: December 18, 2017, 08:16:14 am »
The exact same thing crossed my mind when I saw that picture.
And you will need two keyboards if you're after an impressive performance. Way to go  :-)) :}
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.  Carl Sagan
T33cno
« Reply #944 on: December 18, 2017, 04:25:43 pm »
Thank you Hama :-))  glad you enjoy it.
Thanks Tafel  :-))
Actually fitting the keys on the piano now that will be a chore  {-)
T33cno
« Reply #945 on: December 18, 2017, 09:28:57 pm »
Satin lacquer just creates the right sheen on the back
T33cno
« Reply #946 on: December 19, 2017, 10:21:27 am »
iphone10
Starspider
« Reply #947 on: December 19, 2017, 03:12:40 pm »
Very nice work, coming together well
colin
T33cno
« Reply #948 on: December 19, 2017, 04:38:50 pm »
Cheers Colin
Meanwhile while the garage sale is in progress......
I've made a start on the mast platform. I must crack on as a lifeboat is imminent.
This is all make it up as you like, no idea how I'll fit it yet.
T33cno
Re: MMM Portgarth build......cooking on gas!
« Reply #949 on: December 19, 2017, 09:37:37 pm »
Mast access platform went like a charm right off the cuff beyond my wildest dreams.
I used a gas iron to avoid having to contact the brass parts and move them.
Using spacers wedges and all manner of improvisation I made a successful evening  8)
The only points that will eventually be glued are the three legs of the mast, everything else just looks like its fixed.
I started by slotting the mast to take the frame but I filed a C section in the frame so it doesn't interfere with the mast possible cable route
Page created in 0.165 seconds with 17 queries.
