Author Topic: Work Shops  (Read 3140 times)
GaryM
Work Shops
« on: May 06, 2008, 11:35:28 pm »
I have bought my kit, motor, RC, batteries, prop, ESP, glue, fibreglass and resin, Dremel and such like, but what's the ideal 'shed / workshop' set up?
My shed will be an 8ft x 10ft (when I've got the ground cleared) and I will fit it specifically for my boat building.
(Dad doesn't know this yet, he thinks that he can over winter his Chrysanthemums in it ;D)  - I'm sure some sort of agreement can be sorted though!
Are there any 'must haves? Pillar drill, Lathe, Miller etc.
Has any one got any thoughts / photo's of your workshop and tools needed?
regards
Gary
catengineman
Re: Work Shops
« Reply #1 on: May 06, 2008, 11:54:27 pm »
Yes ALL of the above but minus the Chrysanthemums !
 O the biggest must have A BIGGER SHED ? GARAGE O0 ;D
R,
portside II
  • tugs at rest
Re: Work Shops
« Reply #2 on: May 07, 2008, 12:28:32 am »
Thing is ,it dont matter how big your shed/workshop/garage is it will never be big enough.
daz
GaryM
Re: Work Shops
« Reply #3 on: May 07, 2008, 12:33:39 am »
Thanks both O0
Gary
Roger in France
Re: Work Shops
« Reply #4 on: May 07, 2008, 06:35:35 am »
For me, a new workshop must have the largest, firmest workbench you can arrange. If possible build it in (mine has a sub-deck of a railway sleeper!). There is nothing worse than a bench which bounces. If you cannot build it in make a very, very heavy frame.
Then if you need a construction table to walk around (and adequate space) a portable tabletop on trestles will be fine.
Roger in France.
Re: Work Shops
« Reply #5 on: May 07, 2008, 06:40:50 am »
Currntly my workbech is a small old kitchen table with a piece of block board on top, with batten around the edge (underside) to stop it moving around.
The batten board means I don't paint/drill/chip the table.
It is a poor subsitiute for a proper bench, but is ok unless I need to saw something.
Bunkerbarge
Re: Work Shops
« Reply #6 on: May 07, 2008, 08:21:12 am »
One of the most usefull things I have bought over the last few years was a kitchen island trolley.  This enables me to walk around the model I am building and move it around safely.  There is nothing worse than having to constantly turn your model around on a workbench to get to the other side when you always run the risk of damaging something.
Of course I am lucky enough to have the space for it but if you have it is well worth thinking about.  Probably not one of your first aquisitions though.
GaryM
Re: Work Shops
« Reply #7 on: May 07, 2008, 01:00:53 pm »
Thanks guys
I will be building a frame out of 4" x 4" and fixing it directly to the shed, my last shed had an off cut from a kitchen work surface - heavy and flat.  The price is a bit steep though for a new one.
Anyone bought any power tools from Aldi?  (pillar drill grinder etc.)  I saw a pillar drill a few weeks ago in Aldi - it looked fine and was a good price.
regards
Gary
Re: Work Shops
« Reply #8 on: May 07, 2008, 08:23:19 pm »
I have recently purchased the Aldi pillar drill, and found it to be quite a bargain. There is adjustable speed control with different gear wheels, but I have found it not really necessary to change speed yet.
It's a quiet runner and vibration free, and even comes with a vice to hold the parts under the drill tip.
Hope this helps
Ken
Bunkerbarge
Re: Work Shops
« Reply #9 on: May 07, 2008, 08:51:35 pm »
I once had a belt driven pillar drill and it did tend to rattle and bang around a bit.  Cheap and cheerfull but I would go for a gear driven unit if you are after accuracy.
GaryM
Re: Work Shops
« Reply #10 on: May 07, 2008, 10:41:56 pm »
Thanks Ken and Bunkerbarge.
I'll keep an eye out at Aldi - they have different tools at different times. :)
The belt driven idea is a bit too much for me, but I suppose you could power more than one tool? :)
regards
Gary :)
boatmadman
Re: Work Shops
« Reply #11 on: May 07, 2008, 10:49:53 pm »
Nice one Gary!  {-)
The belt drive is within the pillar drill from the motor to the chuck spindle - not external!
Ian
GaryM
Re: Work Shops
« Reply #12 on: May 07, 2008, 11:52:37 pm »
Sorry Bunkerbarge and Ian, I'm on a different planet tonight!
With the degree of professionalism seen on this site, it seemed normal to think powering more than one tool from a belt driven assembly entirely reasonable.
I was looking at a model steam engine site recently and saw some 'belt' driven accessories, powered by a steam / electric engine. (modern ones)  I used saws, drills, millers on this principal when I was a Pantographer.  (I've finished digging)  :embarrassed:
Gary : :)
Page created in 0.156 seconds with 17 queries.
