Having received my Steve Neil model of the USS Blueback (thanks Pete) the first thing that hits me…is it’s not fibreglass! I’ve been quite happy in the past chopping and drilling through one of John Darnell’s Type V111’s, and shovelling in tubs of P38 car body filler to get the thing looking reasonable after surgery, but this stuff is totally new to me.
I’ve never before worked with ABS/styrene ( whatever you call the stuff) not to this extent anyways, so I’m going to need some help here guys…here we go then.
(1) What is the best adhesive to use to glue the hull sections together?
(2) What is the best filler to use to fill in the gaps?
(3) I take it that the hull sections will need some form of strengthening from inside when it all goes together, so is it OK to use offcuts from the mouldings glued along the joins from inside?
(4) What’s the best adhesive to use for glueing in the internal bulkheads?
(5) Would silicone sealant stick to this stuff?
Thanks in advance chaps…
Cheers,
