Author Topic: HMS Hardy  (Read 5181 times)
cwmitch
HMS Hardy
« on: July 01, 2008, 08:41:39 pm »
Me again, Just thought I'd try and pick your brains a little.
I'm after any info on the Q gun structure on Hardy the H
class leader lost at Narvik  I've got the J English book A to I
but that doesn't really help. So I guess it's over to you please.
Colin..
Re: HMS Hardy
« Reply #1 on: July 01, 2008, 08:49:23 pm »
I think Fleetscale do a plan to go with their hull: http://www.fleetscale.co.uk/pages/hullkits/hardy/hardy72.htm
cwmitch
Re: HMS Hardy
« Reply #2 on: July 01, 2008, 08:56:07 pm »
Thanks Colin unfortunately it's the usual plan and profile which doesn't
help i.e. it's not so much the top but the under side of Q position I need
help with. But thanks for the quick reply anyway.
Colin..
Re: HMS Hardy
« Reply #3 on: July 01, 2008, 09:40:10 pm »
Without looking into it in more detail I would imagine that it is similar to the B gun position. i.e. a "dished" supporting deck with reinforcing angles on the underside to act as a blast screen. The central portion would need to be solid to absorb the stresses caused by firing the gun.
cwmitch
Re: HMS Hardy
« Reply #4 on: July 01, 2008, 09:48:24 pm »
I'll look into what you've said Colin it makes sense! I guess I could
try the NMM but after there quote for Belfast plans I'm not so sure.
Colin..
Re: HMS Hardy
« Reply #5 on: July 01, 2008, 10:03:11 pm »
I've found the following pictures of Codrington and Hardy which tend to support my assumption.
cwmitch
Re: HMS Hardy
« Reply #6 on: July 01, 2008, 10:15:27 pm »
Cheers Col and once again thanks for the quick reply.
Colin..
Re: HMS Hardy
« Reply #7 on: July 01, 2008, 10:16:40 pm »
It's what Mayhem's for!
John R Haynes
Re: HMS Hardy
« Reply #8 on: July 02, 2008, 11:01:44 am »
I have Dave Sambrooks plan of HARDY , if you need I could scan any section?  johnrhaynes,[email protected] these structures were generally for  the main engine vent dischage louvres which discharged on all four sides and  similar to the Ashanti model layout I built at the beginning of the year.
cwmitch
Re: HMS Hardy
« Reply #9 on: July 02, 2008, 07:43:02 pm »
Thanks for the reply John, Having hunted again I've also found a set of
Sambrook plans for Hardy ie the second set that came with the hull not
just the plan and profile I already had?
P.S. I have a look at your Tribal build for some pointers.
John R Haynes
Re: HMS Hardy
« Reply #10 on: July 03, 2008, 10:06:03 am »
If the plans/photos  still do not show the detail of this structure I may be able to give you more guidance . So if you need , contact me on---- [email protected] and I will make a sketch  of the part and scan it to you .
Page created in 0.141 seconds with 17 queries.
