Hi Steve what do you want to do with it give us all a clue them probably we can help......we hope!!!
Stavros:
I want to have a play with using dynamic counter-balancing. I have a couple of very shoddy foamglass hulls to play with. The idea is to mount a weight ( lets say 1/2kg ) on a springy bar that projects out of the top of the boat. The deafult position is that the bar points forwards, towards the bow of the boat.
This is lnked to a a servo, which is then linked to a mixer, which mixes with the rudder.
When the boat goes into a sharp left turn, it naturally rolls over, increasing wetted surface. So if the bar swings out to the right. After some fiddling with the mixer, the boat then stays vertical and wetted area is reduced. Obviously adds more pressure to the rudder, but hey ho.
It'll look ugly, but it's only to test the concept. There is a "cunning plan" in the works, but need to test some idea's out first before I go off building a proper model and this is one of them.
Thanks to all for the advice. I will have a look at each of them.
Steve
