Author Topic: what size speed controller?  (Read 2412 times)
jim w
« on: July 06, 2008, 04:55:33 pm »
I am building a tug powered by 2 x 545 motors and a 6v 4.5A lead acid battery .....what amperage speed controller should I go for? Many thanks, jim   O0
Re: what size speed controller?
« Reply #1 on: July 06, 2008, 06:44:08 pm »
If using 1 ESC a 20 amp should be fine but fuse it at 15 amps.
justboatonic
« Reply #2 on: July 06, 2008, 09:08:18 pm »
The new ACTion twin motor ESC and combined mixer is ideal. Im currently using this set up (6v, 4.3ah SLA) in Drumbeat and the ESC wasnt even warm after about 40 minutes use.
Stretch
« Reply #3 on: October 07, 2008, 06:30:00 pm »
I find the biggest speed controller the better and then fuse the motors down . Get a prop stuck in the weeds and you can blow an electronic speed controller easy.
Electronics are only as strong as the weakest link ... you could have everything rated for 30 amps and hook up a 10 amp speed controller, well you know what will blow when you have a problem. I would sooner blow a 10 or 15 amp fuse.
Page created in 0.011 seconds with 16 queries.
