December 20, 2025, 04:26:36 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Chit-Chat
motor cooling coils
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: motor cooling coils (Read 3081 times)
ando
Guest
motor cooling coils
on:
August 05, 2008, 12:20:06 am »
hi i am quite new to this hobbie
i know that the inlet tube sit,s behind the prop and then on to the coil but were is the best position to site the outlet tube ( fitting ) ????
If two motor used !! yes i know inlet near prop !! but do i need to site both outlet tubes ( fittings ) together ???
Regards Ando
andyn
Guest
Re: motor cooling coils
Reply #1 on:
August 05, 2008, 12:33:04 am »
On a single motor setup, you go straight out the side of the boat, 90 degrees to the motor, With two motors, you can either go for two outlets, one either side of the boat, or both outlets on one side of the boat, again, straight out from the motors
ando
Guest
Reply #2 on:
August 08, 2008, 08:42:18 pm »
hello thanks for the info
Print
Pages: [
1
Go Up
« previous
next »
Chit-Chat
motor cooling coils
