Author Topic: What's a Scuttle Key?  (Read 3709 times)
mrsgoggins
« on: August 06, 2008, 04:46:51 pm »
One is indicated in a drawing in "British Steam Tugs" seemingly attached to the boiler casing of a TID tug.
mrsgoggins
catengineman
Re: What's a Scuttle Key?
« Reply #1 on: August 06, 2008, 05:35:05 pm »
It was normally a small T shaped key used to open the scuttle hatch to enable coal coke to be loaded into the bunkers
The hatch was normally on the side of the accom with a chute leading down to the bunker store.
R,
RickF
« Reply #2 on: August 06, 2008, 08:33:09 pm »
Something like this maybe? In the old car world we call it a budget lock key.
Rick
Proteus
« Reply #3 on: August 06, 2008, 09:36:27 pm »
I think they may be a bit like this so you can lift it off, bit like a drain cove lifter
Proteus
catengineman
« Reply #4 on: August 06, 2008, 09:52:15 pm »
Thats the sot=rt of thing and some are just J hook type tee bars it all depended on whether the engineer had droped the original over the side  {-)
R,
BlazingPenguin
« Reply #5 on: August 07, 2008, 09:43:49 pm »
Alright........despite some research on this matter in the 'reading room' I cant find mention of such a thing on the TID section.
Where is that in the book please?
(Amazing what we find to look at there eh? LOL  :D)
mrsgoggins
« Reply #6 on: August 08, 2008, 10:04:00 am »
My thanks to you all for your help. Now I know the answer, it's obvious.
BlazingP. You need to use a magnifying glass on the TID drawing.
mrsgoggins
Bryan Young
« Reply #7 on: August 08, 2008, 06:12:14 pm »
I've been watching this one for a couple of days. Quite amusing. If you look at a Coaling Scuttle it will generally have 2 holes in it.
The "T" bar handle will have 2 prongs. Prongs fit holes. Turn "T" bar and loosen or tighten. Oddly enough, they are still in use today. The "flush-mounted" refuelling points on some RFAs still have screwed in cover plates that neen this sort of "spanner".
But there is anther sort of "scuttle key". I presume the subject is about "coaling scuttles" and not about "scuttles" (i.e. "Portholes"). Different thngs altogether. BY.
Notes from a simple seaman
catengineman
« Reply #8 on: August 08, 2008, 07:28:23 pm »
So true Bryan  O0
Your presumption is correct ;D
Dave Buckingham
« Reply #9 on: August 09, 2008, 06:29:16 am »
Hi
Bryan has brought up the other or to me normal scuttle/porthole we often had keys to tighten these down
BlazingPenguin
« Reply #10 on: August 09, 2008, 12:20:01 pm »
Cheers MrsG....blimey!...your eyes are good!  ;D
catengineman
« Reply #11 on: August 09, 2008, 10:34:37 pm »
Hi
I only know that as a "DOG SPANNER" which is different to the key
the key has bits sticking out from its shaft and the dog spanner was a mirror image IE had slots in a tube typ of thingy
R,                          (had a few beers so memory fuzzed)
