Author Topic: My Tug As Come in !!!  (Read 3951 times)
salty Nscaler
« on: September 14, 2008, 11:28:16 am »
Well I wake up Saturday and they she be at the front door !!  The Dumas Carol Moran and what a let down :embarrassed: Don't know what I was looking for but god not what I found when I opened the box.Now don't get me wrong but the bollards must be built out of doweling ?? come on how cheap can they get eh? The laser cut wood was well done !! but I'm sort of stuck i can't return it because in shipping one of the wood parts came away from the form so its now "USED" and the hobby shop told me :( The mast is also a PC of wood doweling so to install running lights I need to buy a PC of brass tubing so I can wire it up,Well I guess I should have known you get what you pay for Its packed back up and will go to the 1st train show in Oct maybe I can at least break even :-\
Larry
salty Nscaler
Re: My Tug As Come in !!!
« Reply #1 on: September 24, 2008, 02:29:44 pm »
OK SO I'm building the Carol Moran its comming along fast  and well tired posting pics but can't seems to do so once I can I'll post a few of the build 8) and thank you Colin for all your help O0 lets see if this post  :-\
salty Nscaler
« Reply #3 on: September 25, 2008, 12:38:02 pm »
OK here I hope are some pics, Thank you Martin for your help
 Deck is not glued in yet doing a test fit
sanding block on soft sponge great for sanding the round bits
salty Nscaler
« Reply #4 on: September 28, 2008, 10:47:48 am »
SO right now I'm having a parts issues and I'm thinking just to bug out now,but I did made head way on the barge,been reading a  blog about a  guy named Brooks built a few out of rubbermaid,well here's mine so far,I plan to pick up the rest of the lumber Sudnay and hope to have the frame work done then I'll be able to order what parts I need to finish.Brooks I thank you O0 what a great way to build a fleet of barges. 8)
Yes the sun does come out in washington state in even September!!
TugCowboy
« Reply #5 on: September 28, 2008, 06:19:36 pm »
Got a link to that Blog Salty?
Alex
salty Nscaler
« Reply #6 on: September 28, 2008, 10:32:37 pm »
Hey Tug, I guess that would help eh? so here you go 8)
http://www.rcgroups.com/forums/showthread.php?t=714083
amdaylight
« Reply #7 on: September 29, 2008, 01:52:41 am »
I kinda of know how you felt when you opened the box, I have the Mount Washington and when I opened the box all of the cabin walls and the paddle box sides were vacuformed plastic with very poor detail.  :o >>:-(  I mulled over what my options were, take it back to the shop (not doable it was a special order for me), try and sell it (really didn't want to do that I really liked the boat) and finally put it on the shelf until the urge to build it right came over me and that is where I am at now.
Making the bollards out of wood is one way of making them so anybody can build it and if they are long enough they can go through the deck and be secured to the frame for some real strength. If the don't, look at adding frame work so they can be secured to something more than the deck. Think about it, this may have been a blessing in disguise. ;) O0
Rereading the directions, reading builder logs on the web to see what others had to say about this kit. Now I am at the stage of planning my attack on the kit, what I can use out of the kit, what I am going to change, what I am going to toss in the trash can. This is when the term "Modeler" begins to mean something, this is also where a great sense of accomplishment comes in, "I took this piece of @%$**! kit and turned it in some thing beautiful. Go for it and don't look back. And enjoy the build. O0 O0
Andre  :) O0
over here in Portland Oregon
PS I always go into a kit figuring that I am going to toss some of it in the trash because it just does not meet with my expectations. ;) O0
salty Nscaler
« Reply #8 on: September 29, 2008, 03:36:05 pm »
Andre,LOL I guess great minds do think alike  O0 I have placed the box right on top of my spray booth so I see it ever time I go over to my shop to play (aka work) I just picked up a piece of 1/4 birch plywood for the deck and walls of my barge d and been think of just comming up with a whole new cabin for the tug.Like I tell ppl its a hobby so just like the trains I'll do it my way till then I'm going to work on the barge nee to order parts from harbor models by the way I'll be in Portland next June for the N scale collector's convention 8) Larry up here in Arlington Wa
amdaylight
« Reply #9 on: September 29, 2008, 05:25:58 pm »
Larry,
I noticed that the hull came in two parts and that you had to glue them together, before you get to far along, if it was mine I would rough up the inside of the hull about 2" either side of the join line and then take some light weight glass cloth and put a strip right over the join line to insure that it stays together. If you have a hobby shop that handles RC airplanes they will have the kind of fiber glass strip that you need, the airplane guys use it to hold wing haves together.
Andre :)
salty Nscaler
« Reply #10 on: September 29, 2008, 10:28:28 pm »
Andre,yep thats what I did sanded,clamped, glued let it dry sanded off the flange then ran a strip of glass down the center when I water tested the hull I filled it with lots of change till  the hull was about 2 inchs above the water left it over nite and the next morning it was dry as could be 8)
Larry
