Author Topic: transformer  (Read 4715 times)
tonysmoke
transformer
« on: September 26, 2008, 08:45:43 pm »
 :-\hi all from jersey, hope some one can help i am looking for a transformer  240 to 12 vt  if someone can help regards  tonysmoke,
t le b
boatmadman
Re: transformer
« Reply #1 on: September 26, 2008, 08:50:17 pm »
hi,
If you mean 240v mains to 12v dc, you cant do it with a transformer, you need a rectifier.
tonysmoke
Re: transformer
« Reply #2 on: September 26, 2008, 09:13:53 pm »
hi Ian  you have lost me now, help wot is a rectifer,  i have a pro-peak constellation charger and it runs on 12v thanks tony
t le b
Sandy Calder
Re: transformer
« Reply #3 on: September 26, 2008, 09:24:23 pm »
Hi Tony,
You mean a 12 volt power supply unit.(PSU)
The pro-peak charger is a field charger of some sort,probaly for fast charging race packs.
There may be issues unless your PSU is very high current...I don't know for sure.
It may be designed to draw from a 12 volt battery or a car's cigar socket.
Sandy Calder
tonysmoke
Re: transformer
« Reply #4 on: September 26, 2008, 09:36:19 pm »
thanks sandy i have tried a pro-peak 240mains to 12volt power supply 13.8v and it blew up sent it back to westbourne twice, thay can do no more,
t le b
Sandy Calder
Re: transformer
« Reply #5 on: September 26, 2008, 09:48:55 pm »
I see the IP2000  Pro-Peak Power Supply  is capable of 20 amp.
That translates to 240 watt where the charger can deliver 120 watt max.
I'd recommend you stick to a 24 amp hour leasure battery.
I wonder what sort of overload protection the PSU has or if it has a current limit.
An engineers bench top PSU usually has a dial current limit.
tonysmoke
Re: transformer
« Reply #6 on: September 26, 2008, 09:53:08 pm »
thanks sandy, i will look into a leasure bat ,looks like the way to go regards tony,
t le b
Re: transformer
« Reply #7 on: September 26, 2008, 10:06:01 pm »
Constellation Pro-Peak Charger
from Ripmax
Main Features
• Fast Charge and Discharge
- 1-25 cell NiCad/NiMH Batteries
- 2-12v lead Acid Batteries
- 3.6-14.8v Lithium Ion/Lithium Polymer Batteries
• 100-700OmA Fast Charge Current (120Watt Maximum)
• 100-300OmA Discharge Current (20 Watt Maximum)
• User Definable Memories for
- Battery Pack Type, Number of Cells, Capacity
- Charge/Discharge Current
- Delta Peak sensitivity (NiCad/NiMH only)
• 2 Line LCD Display
• Delta Peak Detection/Zero Current Voltage Check
• Temperature detection voltage cutoff
(NiCad/NiMH only)
• 12v DC input voltage
• Audible Function Alarm
• Integral Cooling Fan
http://www.sussex-model-centre.co.uk/shopexd.asp?id=4985
Re: transformer
« Reply #8 on: September 26, 2008, 10:09:51 pm »
thanks sandy i have tried a pro-peak 240mains to 12volt power supply 13.8v and it blew up sent it back to Westbourne twice, they can do no more,
If you're blowing up the recommended PSU, that sounds like there is something wrong with your charger!
Personally, I use a modified PC PSU  - http://www.modelboatmayhem.co.uk/forum/index.php?topic=10935.0
I also use a 15v laptop power adaptor for another charger.
boatmadman
Re: transformer
« Reply #9 on: September 26, 2008, 10:20:54 pm »
Sorry, I confused things there - I didnt click onto the fact you were meaning a charger circuit.
Re: transformer
« Reply #10 on: September 27, 2008, 09:57:58 am »
hi,
To clarify (?), To get from mains, (240V AC) down to 12 volts, you use a transformer.  You now have a nominal 12 V AC.  To turn this into DC, you need a rectifier, usually 4 diodes wired appropriately, or a bridge rectifier, which is one lump containing 4 diodes that somebody else has wired for you.  The nominal 12 V DC that you now have will need a regulator of some sort to prevent damage to whatever it is powering.  There are, of course, lots of variations on the theme.
Sandy Calder
Re: transformer
« Reply #11 on: September 27, 2008, 11:20:49 am »
hi,
I couldn't put it better.
You'll notice plug in PSU's are getting smaller lately as 31 kHz transformers replace clunky 50Hz transformers in the consumer market
If it's not 100% clear what this thread is about.
an £ 80 field charger  in the picture is blowing a £35 20 amp IP2000 switch mode psu by the same "brand"
Sandy Calder
Re: transformer
« Reply #12 on: September 27, 2008, 01:51:39 pm »
Get yourself a mains/12v charger.
I've got a Jamara X-Peak 220. Runs off mains and a 12v DC input
Does Nicads, NIMHs, Lead Acid and Lipos
About £80 from dealer in the Mayhem List (usual disclaimer)
Doug
tonysmoke
Re: transformer
« Reply #13 on: September 27, 2008, 05:05:40 pm »
thanks all for all the help, new 240volt charger on its way,  cheers all tony , jersey
t le b
Page created in 0.021 seconds with 18 queries.
