Author Topic: Prop size  (Read 6193 times)
stobby256
Prop size
« on: October 08, 2008, 09:01:22 pm »
Hi Guys,
Is there guide as to what prop size I should start with? It was easy with aircraft   :'(
So I'll run a 48" mono hull sports boat, twin 700BB Turbo motors, and a choice of props from 30 - 80mm!!!!  I know its suck it and see... What should I start with?  Im guessing these props will be submerged.
Re: Prop size
« Reply #1 on: October 08, 2008, 11:08:57 pm »
stobby256
Re: Prop size
« Reply #2 on: October 09, 2008, 01:33:32 pm »
OK - so 40-50mm would be a great starting point.
Looking from the back, which way do the props turn...  LH goes cwise, RH goes anticwise....  does it matter? As they are not surface piercing props, Im aiming for them to protrude just below the hull. obviously as parallel to the hull as I can...  ::)
Many thanks!!!
Steve
Re: Prop size
« Reply #3 on: October 09, 2008, 01:41:48 pm »
Looking from the back (towards the front), usual rotation is Anti-Clockwise.
Re: Prop size
« Reply #4 on: October 09, 2008, 01:43:29 pm »
BTW: there are some nice propellers here....  http://www.seawear.com/jewelry/propellers.html
stobby256
Re: Prop size
« Reply #5 on: October 09, 2008, 02:00:04 pm »
Great - what abpout a contra-rotating set up?
 :kiss:  Not sure about those props.....  The brecelets are more my thing  :kiss: :kiss:
ronkh
Re: Prop size
« Reply #6 on: October 09, 2008, 02:56:45 pm »
Re: Prop size
« Reply #7 on: October 10, 2008, 05:58:00 pm »
A good read about props (full size) here: http://www.boatfix.com/how/props.html
BJ
Re: Prop size
« Reply #8 on: October 11, 2008, 05:26:33 pm »
Hi Guys,
Try the attached jpeg and take your pick.
stobby256
Re: Prop size
« Reply #9 on: October 11, 2008, 08:22:11 pm »
 :-))  WOW!   :-))
MANY THANKS!
Re: Prop size
« Reply #10 on: October 11, 2008, 09:12:31 pm »
stobby256,
You could always give Simon at Propshop a ring (I believe he is still working for the company) and get advice from those who make them.
A good while ago I phoned him and asked, he made what I thought was a daft suggestion, so to prove him wrong I fitted his suggested props.
A big piece of humble pie was eaten, the model well exceeded my expectations and I am an experienced modeller.
We can all learn something.
stobby256
Re: Prop size
« Reply #11 on: October 12, 2008, 06:47:25 pm »
Cheers shipmate60!!
I'm on the case!
PkBoo
Re: Prop size
« Reply #12 on: November 28, 2008, 02:46:16 pm »
Hi Stobby, Iīve found out that the only proper way to find the right prop is to test and test again. Water is barely compressible so you cannot scale it as with air. As you said itīs a lot easier with a plane. Lately Iīve been building (actually kitbashing {-) ) a speeder with a PT hull and found that with a 30mm prop I could fully exploit a BL motorīs speed at 4300Kv without any real issues with heat development. Mind you Iīm only using a 3s Lipo pack and that thing just flies. I hope to setup a vid coming weekend so I could show and tell. GL on the choice. Boo
Page created in 0.02 seconds with 18 queries.
