Author Topic: Shaft and pushrod seals  (Read 7399 times)
mac.one
« on: October 14, 2008, 09:09:41 pm »
Hi All
        Is there anywhere in the uk where these can be purchased
                               Regards Julian
sheerline
Re: Shaft and pushrod seals
« Reply #1 on: October 14, 2008, 10:50:24 pm »
Julian, what boat, what shafts and what type of pushrods?? Any pics?
Chris
mac.one
« Reply #2 on: October 15, 2008, 03:44:44 am »
Hi Chris
             Boat will be a Victor 3 class shaft dia. 4mm, pushrods (linkages) can be to suit the seals  sure the last ones i got were from subtech but there seems to be little on there website now they were the O ring type seals which screwed into the endcap (Although I'm not sure these are suitable for the RCABS-R ballast system) if you can help i would be most gratefull. As for pic's i do have some of one i made about a year ago.
                                        Regards Julian.
Guy Bagley
« Reply #3 on: October 15, 2008, 09:18:55 am »
i used to get mine from subway designs, but i know they are no longer trading
sheerline
« Reply #4 on: October 15, 2008, 10:14:31 am »
Hi Julian, I think if you managed to get particular types of seals for this type of unit then the best plan would be to contact Dave again. Try giving him a call at Subtech, his number is: 01458 270097.
Although I make waterproof motor glands and pushrod seals, they may not be suitable for your particular unit so best to try and get the correct ones to keep life simple and avoid modifications.
Hope this is of some help.
Chris
Subculture
    • Dive-in to Model submarines
« Reply #5 on: October 15, 2008, 05:18:04 pm »
The ones that Francis used to sell were from Norbert Bruggen. You can buy them direct from Norbert if you contact him via his website-
http://modelluboot.de/Zubehoer/Dichtungen.html#WDR
They use an o-ring and in a compression gland configuration.  Norbert can speak good English, and he also takes paypal. Ordered from him a couple of times, and have received the goods within a few days of ordering.
I don't think you can get the Subtech seals at the present.
Andy
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #6 on: October 15, 2008, 06:31:31 pm »
The SubTech site is back up http://rcmodelsubs.com/  , now a separate enitity from Pandan Models.
Subculture
« Reply #7 on: October 15, 2008, 07:41:54 pm »
BTW, I notice you are using a piston tank in your module. Don't use Subtech seals with a cylinder that pressurises inside. This is because they use lip seals, and they push outwards as the pressure increases on the inside.
Bellows work well, or use the seals that Norbert sells.
mac.one
« Reply #8 on: October 17, 2008, 12:19:42 am »
Hi All
         Many thanks for all your replies i will ring norbert tommorrow.
                                               Thanks Macone
robbo770
« Reply #9 on: October 21, 2008, 12:38:43 pm »
Just to let you know the SubTech seal do work if you want to have a pressure tank system too, we have an upgrade for them with supporting 'O' rings to stablize the seal face,
but it up to the builder to which he prefers
just for reference Andy
thanks
Rob
SubTech O0
Subculture
« Reply #10 on: October 21, 2008, 03:49:40 pm »
Fair enough. That must be a fairly recent modification, as I've never seen that advertised before, and Skip used to advise caution against using the seals in an internally pressurised boat. I know some people used to swap the lip seals out for o-rings, but when Norbert's come with them as standard it seemed a bit pointless really.
Andy
Sub driver
« Reply #11 on: October 21, 2008, 05:00:49 pm »
Robbo770.
Has Sub tech changed hands or is Dave still the owner ??
Regards Sub.
robbo770
« Reply #12 on: October 29, 2008, 09:10:13 pm »
I am now the owner of all SubTech for any sales in UK, USA and Europe, there is no other outlet now,
I can only advise that there was a company restructure when I bought it and the rest is history as they say,
thanks
Page created in 0.15 seconds with 18 queries.
