Author Topic: Envoy Class Tug (Pictures)  (Read 4331 times)
Mickymike
« on: October 15, 2008, 08:08:49 pm »
Hi All
I thought I would just put a few pictures of my Envoy Class Tug it is powered by a Bhuler SP18t Motor driving a 5 bladed 80mm prop. 12 Volt with a 20 amp Viper speed controller Current draw on full load only 2.8 Amps, running on 2.4 Ghz
Bunkerbarge
Re: Envoy Class Tug (Pictures)
« Reply #1 on: October 15, 2008, 10:14:20 pm »
Lovely job there.
I think of all my models my favourite is still my Envoy class tug.  Nice model, handles great on the water, loads of room in the hull and with a 12v 7ah battery goes for hours.
Interesting that you have used a Buhler.  Mine has a geared Hectaperm in it which does the job but it does make a bit of noise.
Mickymike
« Reply #2 on: October 16, 2008, 08:06:24 am »
Hi
Thanks for the comments
I use the Bhuler motor because they are very efficient they are 24 Volt and 12 pole, on 12 Volt it does 1550 Rpm as is deadly quiet and very responsive to the speed controller inputs
I have never run it on 24 Volt because of the Voltage limitations of speed controllers i know there is one on the market that will take 24 Volt but I dont really like it but I am quite happy with 12 Volt
I also have a smoke generator fitted to the Envoy and it looks great with the smoke belching out, as you say it is a super tug.
barryfoote
« Reply #3 on: October 16, 2008, 08:38:40 am »
Mike,
A real beauty....What smoker do you have in her?
Barry
Mickymike
« Reply #4 on: October 16, 2008, 03:19:00 pm »
Hi
Thanks for the reply
The smoke unit I use is a modified Hunter Systems I can send you details of the mod if you like, it works incredibly well and as you increase the throttle the smoke increases as well.
Hagar
« Reply #5 on: October 16, 2008, 05:09:34 pm »
What a fine looking vessel she is!
How big is it, in the picture with the back of your car in it looks hugh, the tug that is!
Is it built from a kit or plans?
Nice!
Mickymike
« Reply #6 on: October 16, 2008, 06:27:59 pm »
Hi
The vessel is 1/48th scale..43 1/2 inches long 9 3/4 beam displacement 27 lbs. It is a Model Slipway kit you can get it in Civilian or Military versions
craftysod
« Reply #7 on: October 16, 2008, 06:33:24 pm »
A lovely presented tug their mickymike WD
Pointy
« Reply #8 on: October 16, 2008, 06:38:04 pm »
Beautiful work!!! :-))
Page created in 0.016 seconds with 15 queries.
