Author Topic: help with a Cheddar Gemini  (Read 3064 times)
Duke
« on: October 23, 2008, 03:31:11 pm »
I purchased a Gemini Engine with boiler from a friend a few years ago that was in a new state. I have only run it once since then to show my Grandson it working.
Last month I was in a position to purchase a Der Seekadett kit still in the box at a good price.
I decided to try the engine but discovered that it had seized up the piston flywheel end. Not really knowing the layout of the engine, I stripped it down and freed the piston but I had removed the steam chest which afterwards found out that I did not have to do that and typical the valves dropped out and I lost the timing.
I have managed to get the engine running on a small compressor, not sure of the pressure cant be much above 10PSI,
but it will only run one way will not reverse if I move the lever over and try to turn it there seems pressure against it.
So can anyone please help Having not had any knowledge of steam engines I am at a loss.
Does the reversing lever face the same way as the engine is turning? I have to hold the lever otherwise it moves on its own to the centre postion, I cant remember if it was like that when I first tried it. If the engine is turned by the flywheel the lever moved the same direction, I was wondering if when trying to turn the engine when it was seized I have moved the eccentrics but they are pinned or the gearing somehow.
Any help in the matter would be greatly appreciated.
Thankyou
Duke
Page created in 0.168 seconds with 15 queries.
