Author Topic: Magnetism  (Read 3277 times)
boatmadman
Magnetism
« on: October 30, 2008, 03:40:14 pm »
This is directed at FLJ - (not because of his magnetic personality), but I thought I would post it here because it may be of general interest.
Dave, Are your gizmo's (particularly esc's and switchers) affected by magnetism? I ask because I am thinking of using neodym magnets to hold the superstructure in place on my current build, and there are 5 of your gizmo's plus a multichannel rx very close by.
Before anyone asks, no, I cant move the gizmo's somewhere else, as will become clear when I post pics.
Ian
FullLeatherJacket
Re: Magnetism
« Reply #1 on: October 30, 2008, 06:39:01 pm »
Ian
Cast your mind back to school, and you might recall the theory. If you move a coil of wire through a magnetic field then a current is generated in it, and if you pass a current through a coil then you will generate a magnetic field around it. In other words (here it comes.....) magnets are like MP's; they don't do a damn thing until you kick 'em   ;)
I happily use strong magnets to hold down the S/S on both my Shamrock and Sentinel. I doubt if your classier neodym thingies produce a magnetic field much different from my cheapo door catches, so go for it, good buddy.
BTW don't you work at a power station..........................??   %)
FLJ
boatmadman
Re: Magnetism
« Reply #2 on: October 30, 2008, 07:16:11 pm »
Thanks Dave, and yes, I do work at a power station, but I am mechanical, ellectrikkery is white mans magic!  :-))
Re: Magnetism
« Reply #3 on: October 31, 2008, 11:02:12 am »
To produce an electrical effect, the magnet and object need to be moving with respect to each other.  Once the superstructure is in place, the magnetic circuit should be closed, with virtually no external field.
The only things that could be affected are relays, which might show a tendency to stick operated, but even this is highly unlikely as the relay would have to be in exactly the right position, i.e. VERY close to the magnet.
sweeper
  • When all else fails, read the instructions
  • Location: On the edge of reason, in the state of Confusion
Re: Magnetism
« Reply #4 on: October 31, 2008, 11:43:21 am »
As stated above, you should only get a minimal fringe field from your magnets.
If however you are concerned about the effects after a trial, why not consider making a close fitting metallic screen around each of the magnets. In effect, a Farraday Cage? In industry the idea is used in instruments to protect them from stray magnetic fields and eliminate errors caused by the fields acting on the instrument movement.
Roger in France
Re: Magnetism
« Reply #5 on: October 31, 2008, 11:56:41 am »
I have frequently used quite large, strong neodym magnets to secure hatches etc. without any ill effect on the performance of the gear on board.
Roger in France
