Author Topic: electrics  (Read 2909 times)
leelee
electrics
« on: October 30, 2008, 04:54:26 pm »
hi everyone I'm pretty new to this so bare with me please.I have just rebuilt a cruiser i had given me and Ive fitted everything  (electrics)Well when i switch everything on the servo resets(normal) then a second later the motor runs by it self with out the help from me...does anybody know what i have done wrong and what the fix is i would be absolutely chuffed to know.Thank you for reading..... lee
boatmadman
Re: electrics
« Reply #1 on: October 30, 2008, 05:11:11 pm »
Hi Lee,
Could you give us some more info please, what type esc, motor, radio gear, positioning of receiver and ariel, is the motor supplressed?
leelee
Re: electrics
« Reply #2 on: October 30, 2008, 05:20:19 pm »
im using a crp gt3 turbo 16 turn motor - viper marine speed controller - hitec hp-2rnb reciever -acoms as17 servo -with my origional gewise transmitter.......any help to you
andrewh
Re: electrics
« Reply #3 on: October 30, 2008, 05:32:56 pm »
lee
The symptoms you describe can happen if power is turned on in the boat (plugging the battery in to the ESC) with the transmitter stick at one end or the other
(you did turn on the Tx first, didn't you?)  and the crystals are a pair?
To sort out what the problem is:  unplug the ESC from the Rx - plug in a seperate battery (4.8 or 6V) to the Rx  and see if the rudder servo follows the stick.  If it doesn't the problem lies in the radio somewhere
If it does move the rudder servo lead into the channel 2 socket on the Rx - see if the rudder servo follows the motor stick/whatever.  If it doesn't the problem lies in the radio somewhere - specifically in that channel 2.
Take out the rudder servo and battery plugs and try the ESC in channel 1.
Connect up the drive battery to the ESC - what happens?  Does the rudder stick control the motor forwards and backwards?
If it does you have a problem (only) with channel 2  - probably in the receiver (because it is smaller, wetter and more abused)
If none of this has helped:
When you connect eveything up as usual  and connect the drive battery there are lights on the front of the front of the Viper ESC red and green which should flicker for about 4 seconds, then go off (if the transmitter throttle stick is at neutral).
"Forward" command a the TX should turn the green light on and drive the motor forwards
reverse, similarly red
andrew
boatmadman
Re: electrics
« Reply #4 on: October 30, 2008, 05:36:40 pm »
Andrew beat me to it!
leelee
Re: electrics
« Reply #5 on: October 30, 2008, 05:38:44 pm »
 thanks for the replies i will check all of the metioned fixs....fingers crossed...lee
portside II
  • tugs at rest
Re: electrics
« Reply #6 on: October 31, 2008, 09:26:55 am »
I think you may have hit the nail on the head Andrew , like you said if theres nowt wrong with the radio gear then more than likely the esc is not set up .
In neutral on my viper i get both the red and green lit , have noticed a few members of the goole club are going to change to the new esc's from Mtronics apparently they are set up free ,just switch on and go.
daz
Page created in 0.365 seconds with 17 queries.
