Author Topic: Removing Paint From Resin Figure  (Read 4100 times)
Propslip
« on: December 17, 2008, 09:23:35 pm »
I have a resin figure that has been poorly painted. What is the best way of removing it without damaging the detail. I have used paint stripper on metal parts before & that works very well, but when I used it on resin once it melted the resin!!
                     Propslip
dan
Re: Removing Paint From Resin Figure
« Reply #1 on: December 17, 2008, 09:53:40 pm »
if the figure isnt too small, you could try spraying over it in primer and then redo the paint job the way you want
gribeauval
« Reply #2 on: December 17, 2008, 10:41:32 pm »
Go to your local model shop and buy a tub of Modelstrip. It's a paint stripper designed for plastics so your resin should be safe! Do not try stripping paint with full strength ones, they will melt your figures.
True Lifeboat Nutter!!
Umi_Ryuzuki
« Reply #3 on: December 18, 2008, 06:13:50 am »
The paint should come off if it is soaked in:
Simple Green cleaner
Brake fluid
Easy Off oven cleaner
I have used the simple green, and the oven cleaner to remove paint
from resin parts and there was no harm done to the parts.
Dave Buckingham
« Reply #4 on: December 18, 2008, 06:27:23 am »
I use traffic film remover but it is sold in Gallon cans .
Works very well
andygh
« Reply #5 on: December 18, 2008, 12:08:58 pm »
Modelstrip is made for the job and does it perfectly  :-))
Klunk
« Reply #6 on: July 15, 2009, 04:35:36 pm »
nasil varnish gel works as well. If the paint is acrylic then soak overnight in nail varnish remover in a plastic bag.
full time penguin
