Author Topic: which radio  (Read 2921 times)
first tug
which radio
« on: December 28, 2008, 07:55:38 pm »
Not sure which radio to buy i am building the Tito Neri would like to have six channels to use. Would like to us 2.4 to step into the new era > Does anybody know if MCD (model control device ) will work on 2.4
Re: which radio
« Reply #1 on: December 28, 2008, 08:13:30 pm »
Hi Tug,
The 2.4Gig Hertz radio only refers top the transition signal, the "device side" of the receiver, servo, speed controllers, electronic switches etc. are still all "standard", you just need to check you have the right shape plug for the receiver (usually Futaba) and the 3 wire have the correct orientation. So if the MCD say Futaba compatible, you should be alright!
If you are going 2.4Gig, Spektrum and Futaba are the makes to go for.
Some MCD devices here:  http://www.shipsnthings.com/HTML/controlD.htm
dan
Re: which radio
« Reply #2 on: December 28, 2008, 09:51:36 pm »
Ive had the futaba 2.4 six channel for a while, I'm using all the channels in one of my models and have never had a problem with it
first tug
Re: which radio
« Reply #3 on: December 29, 2008, 09:47:03 pm »
other than channels that are not on the stick how would one go about controlling devices i thought of servos that would push switches put that seem like the old way or is this still the best. Any advice on how to control thing over the four channel on the stick would be great
Re: which radio
« Reply #4 on: December 29, 2008, 11:35:31 pm »
Action electronics Highly reccomended they do two way switchers which will work off a stick or switch,there is another company Electronise(Sorry FLJ I swore) who do one as well.Forget the old fashioned way of using a servo ....old hat
FullLeatherJacket
Re: which radio
« Reply #5 on: December 30, 2008, 09:21:14 am »
First Tug
This should add to your knowledge.
http://www.action-electronics.co.uk/pdfs/Switches.pdf
Beware the Futaba 6EXA 2.4GHz set; the fifth and sixth channels are only 2-way switched, so the best you can hope for is to operate two simple ON/OFF circuits (e.g. lights). If you want a more versatile set then you need one with at least one additional proportional channel i.e. operated by a rotary knob or 3-way switch. Personally I wouldn't buy a 2.4 set yet - there are still issues with them, not the least of which is the increasing number of non-modelling stuff which uses that frequency. I'm still angry about finding a 700 mAH NiCad pack in the back of a brand-new 2008-model Tx. Cheapskates (RipoffMax?).
Martin
The Rx signal output voltage on the Futaba set has been reduced to 2.4v and the pulse frame rate to 14ms. This can affect the operation of some non-Futaba devices like ESCs etc.
Stav
There's a bottle of mouthwash in the post.  %)
FLJ
Max Power
Re: which radio
« Reply #6 on: December 30, 2008, 03:11:24 pm »
FLJ
I have been using Futaba 2.4GHz with Electronize speed controllers in two of my models with no problems. The performance has been identical to when I was using 40MHz in the same models. :-))
OMK
Re: which radio
« Reply #7 on: December 30, 2008, 10:26:02 pm »
One of the reasons I purchased the 9C is that it allows you to customise to your heart's content. The only downside is that 9C implies nine fully-proportional channels, whereas, in reality, the ninth channel is just a basic on/off channel - not proportional.
Every single switch is easily assigned for any particular function, but what the manual doesn't tell you is that the internal software can be manipulated via 2 x secret service menus. All you need is to hook a 1,000-ohm resistor between pins #2 and #7 behind the CAMPac hatch.
Once you're there it's dead easy to reassign any of those switches. For instance, switch 'A' is a 2-position on/off switch. You can easily change this to a 2-position momentary switch, or a 3-position switch, or even change it to a standard 5k pot' for proportional use. You just have to set the parameters and the software takes care of the hard work.
In other words, say you have a servo hooked to channel 5, and it's controlled by a basic 2-position switch, rotating from fully clockwise to fully counter-clockwise. Fine, but what if you want the servo to also come to rest at center position? Simply swapping the 2-pos switch for a 3-pos switch won't work. This is where Futaba have come to the rescue by including all the relevant, clever programming, all easily accessible from the service menus.
Probably useless junk information for most modellers', but interesting to see that there is also the possibility to play around with a zillion other parameters, such as stick re-alignment, total number of hours the radio has been used since purchased, etc, etc..........
